1.6mm steel
BensPlasmaAu
1.6mm steel
Post by BensPlasmaAu »
I am currently using 45 amp consumables for cutting 1.6mm steel, im still to find a good speed compromise as the table is gettimg the bugs ironed out. Woukd I be better off using the 30 amp comsumables for this thin material?????
Home built 3400 x 1400mm (11 and a bit X a bit over 4.5 feet)
Hypertherm Powermax 45
CandCNC Bladerunner IV
Some air dryer off the internet
Another water seperator I found unused on a shelf
Refrigerated air dryer
davek0974
Re: 1.6mm steel
Post by davek0974 »
I have found the 30A consumables at 30A to be most excellent on 1.2mm stainless, speed as per book, height 0.5mm
