Am I out of the ball park . . .
CNCCAJUN
Post by CNCCAJUN »
Looking for pricing guidance . . .
Example attached was done for a friend, but thought I would use it for an example since it is close to the type of work I want to do.
The helicopter is basically 18" X 12" on 16 gauge steel. Painted with rattle can Rustoleum.
201" total cut . . . . 30 pierces . . . 1/2 hour design time @ $25.00 per hour . .(if I knew what I were doing that would be right)
I'm thinking this should sell for $30.00 to $35 as a stock item & probably around $45 to $55 if it was a request and the file was rather easy to create.
Now based on the price sheet from this site I am a little low! I should be at $48.98 . . .and this does not cover painting . . .
Please let me know what you guys would sell this for in either scenario . . . .
Thanks in advance,
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Corfabrication
Re: Am I out of the ball park . . .
Post by Corfabrication »
I've been using Jim's formula and it seems to put me in the right area to make out.
Material cost x2, then cut inches x material(with markup,the first formula) add that to material square inches price
12" x12" @ .05/sq"= 7.20 (material price)
201" x .05= 10.05 (cutting price)
7.20+10.05=17.25 sell price raw.
I would charge extra for coating.
I would add extra time/cost for design if it was something you spent time on.
Now that's a price that seems inline with what we can get in my vicinity. If you can charge more, that's awesome.
m79b01
Post by m79b01 »
In my area I have adjusted the formula and based on what I have I come up with $35 powder coated in 16ga. That is 19x13 220 cut inches and 30 pierces no design time. FYI
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
CNCCAJUN
Post by CNCCAJUN »
Thank you . . . anyone else want to chime in . . .
Ever bit of info is helpful . . .
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Shane Warnick
Post by Shane Warnick »
I would be $16 for the design cut and raw. Add $20 for me to paint it, $25 for powder coat. I don't do my own powder coating but my cost on powder coat would be $15 or a little less. I prefer the powder coating and actually don't paint unless it's a big sign (4 or 5 feet or bigger) as I can get it powder coated easier and make money on that vs shutting down to paint which is a pita. Painting is just too time consuming for me to justify it at this time.
Shane
CNCCAJUN
Post by CNCCAJUN »
Not so lucky on powder coat prices in this area . . .
That Helicopter was quoted at $55.00 to $60.00 . . . :o :o :o
Yep, I would love to find one of these "cheap" powder coaters . . .
This is why I am building a paint booth this week . . .
Dynatorch 4X4 XLS
PowerMAX 85
AnotherDano
Post by AnotherDano »
Steve,
The general rule of thumb for powder coating is $5.00/sq'. And that's one side - don't forget the back side.
I don't use $10.00 because there may be a difference between front and back. The customer has all this explained before I take the piece. If there is a front and back, such as writing that will logically be a 'front' I may charge less and not worry so much about the side that won't be seen. Not that I don't try to make each as perfect as I can, but if there is a run, fisheye or small blemish, I don't strip and recoat.
A clear coat is only 50% more because there isn't as much prep as the base coat needs.
Another consideration is the time it takes to change colors. That's where the delivery time gets stretched out. We like to shoot a lot of stuff with the same color at one time. Usually, I have some pieces meant for the display table that I can use to fill the oven. If the customers' piece the only thing to be coated, I have an oven minimum of $25.00.
And remember, the cost of powder is not determined by the size of the piece but the powder going out of the gun. Coating a bolt uses as much powder as a 6x6" item.
Be careful choosing a coater that is 'too' cheap. If (s)he doesn't ask if the piece will be indoors or out, the first red flag goes up. Some powders are more sensitive to UV and should be coated with a 'super durable' or UV resistant powder if the piece will be in sunlight. Also, they should be asking about a phos treatment depending on the area you're in. La. has more salt in the air so you should be more worried about that than I am in the high plains.
PC ain't cheap. I drench my stuff with denatured alcohol looking for breaks in the runoff. That stuff is $15.00/gallon!
Here is the closest of my associates to you.
Combs Custom Coating
combscustomcoating.com (http://www.combscustomcoating.com)
644 Hwy 469 N.
Florence, Ms 39073
601-573-1141
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
storiesnsteel
Post by storiesnsteel »
your copter at the size mentioned I would sell for 30 unpainted and 40 painted if I had to do the file as well would be 30 extra
Greg From Storiesnsteel
CNCCAJUN
Post by CNCCAJUN »
gcw8 wrote:your copter at the size mentioned I would sell for 30 unpainted and 40 painted if I had to do the file as well would be 30 extra
Wow, I'm moving to Canada . . .
Can you tell me what area in Canada does not have snow? :D
Dynatorch 4X4 XLS
PowerMAX 85
HammerDownJustin
Post by HammerDownJustin »
I would sell for about $40 with rattle can paint. We should be close on prices since our economy is close between Texas and Louisiana.
Miller 251 Mig
CNCCAJUN
Post by CNCCAJUN »
Thanks . . .
$40.00, I can live with that . . . :D
Dynatorch 4X4 XLS
PowerMAX 85
