I have a customer that wants to cut some chickens out of 1/8" brass sheet. I have not done any brass and I was wondering does it mimic copper, stainless or what as far as cutting. any help would be appreciated.
kevin
BRASS PLATE
Re: BRASS PLATE
I have never cut brass, but would think you would have to be really careful with the fumes.
It's soft enough it should cut like aluminum, but again, I have never done it. Where are you even going to get 10g brass sheet??
Just curious, I don't even know where to call the even ask.
Shane
Shane
Re: BRASS PLATE
Nor do I. My customer already has it and I will ask.
kevin
kevin
Re: BRASS PLATE
Alaska Brass and Copper in Seattle has it by the truckload. Just about any brass or copper products you would like they have. Stainless too.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Re: BRASS PLATE
Yes, beware the fumes, it is like welding on galvanized steel due to the zinc in it.
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
Re: BRASS PLATE
Some one here posted they used a door kick plate for their brass should be easy to find at the box stores if your project is small enough.
have fun
tom
have fun
tom
- kb3gun
Re: BRASS PLATE
A lot of those so-called "brass" kick plates are just brass plated. I found that out the expensive way.
-Smitty
Torchmate 4X4 Growth Series w/AVHC
Hypertherm PM45 w/ Machine Torch
Miller Syncrowave 210 TIG
- Oldsarge
Re: BRASS PLATE
That was me with the brass door kick plate.... Here's the motor data plate that I scribed and cut for the belt grinder.
You do have to read the packaging real close to make sure that what you're buying is actually brass! This is 16g I just used the settings for mild steel, same pierce height as cut height, no delay, and let 'er eat at book numbers, or a tad faster depending on thickness.... Since there's mounting holes on the plate, I drew an 9" line and took a few slices off the end until I got results I liked....
And yes, ventilate like crazy! As with rocks (lapidary) and cutting metal, I've found that burning, cutting or shaping anything that turns green is usually very bad for you!
Oldsarge
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
- SeanP
Re: BRASS PLATE
Wow the detail on that plate is amazing!
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
Re: BRASS PLATE
this said solid-brass
http://www.homedepot.com/p/Schlage-6-1- ... /100529587
