Problems with Hypertherm Consumables...
Running a Powermax 65 with machine torch on an Arclight Dynamics 4x8 table.
I have an 80 Gallon Curtis compressor with auto drain feeding a Speedaire refrigerated drier through 3/4" Rapidaire piping, 2 coalescing filters and my shop is in Southern California. Dry, clean air is not a problem.
I have been having an issue with brand new, out of the package Hypertherm brand consumables. I am getting a skewed(angled) kerf on my parts as if the Torch is tilted to one side. I verify that the torch head is 90deg to the plate on both axes when I load each plate.
When I rotate the nozzle 180 degrees in the torch cap, the angle follows the nozzle. This is happening with every combination of used and new electrodes and/or swirl rings installed along with nozzles. It seems to be a problem with the nozzles regardless of the other parts. Both 45A and 65A are doing it but not every nozzle will. Usually about 2-3 out of a pack of 5.
As anyone else had this happen? Anything else I can check or change?
Re: Problems with Hypertherm Consumables...
Have you physically stopped your machine and measured your pierce and cut heights to make sure your heights are true. One low pierce is enough to damage a nozzle.
Is it touch and go? the material isn't flexing and coming back up to give you a false height reading?
Also you are using a machine torch, are you using a machine shield, not a hand held shield?
Murray
Murray
Does the nozzle orifice still look concentric, or is it blown out?
5 x 10 Air bladder water table
Precision plasma HDB gantry
CandCnC 620-4 Bladerunner
Feather touch ohmic plate sensing
Hypertherm Powermax 65
2015 Autocad lt
Mach 3
Central California
2015 Autocad lt
Mach 3
Central California
muzza wrote:Have you physically stopped your machine and measured your pierce and cut heights to make sure your heights are true. One low pierce is enough to damage a nozzle.
Murray
Pierce and cut heights are optimal. There are no pierce problems or damage to the nozzles. The orifice looks to be perfect but is cutting at an angle and only changes when the nozzle is rotated or changed out.
My table cuts beautifully for sheets of material at a time if/when I get a good nozzle. This happens when I go to change consumables and pull a brand new nozzle from the package...instantly angled cuts right after plenty of good parts.
I've been running this table for a year and this has only started happening in the last few weeks.
- tnbndr
Are you sure they are Hypertherm consumables and not imitations packaged to look like Hypertherm? I have heard that is an issue.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
tnbndr wrote:Are you sure they are Hypertherm consumables and not imitations packaged to look like Hypertherm? I have heard that is an issue.
I buy my consumables from either Hypermax Online or from my local Praxair and they all come in Genuine Hypertherm packaging with Hypertherm Laser etching on each part so I hope that's not the case.
I'm not saying that we never have defects, but the fact that more than one from a 5 pack of nozzles is certainly something we never hear. Any chance you can take some good focused, close up pictures of a nozzle that immediately showed sever bevel angles? Can you provide (take torch apart and read the numbers) the part numbers of each part (swirl ring, electrode, nozzle, retaining cap and shield?
Have you changed the swirl ring or the retaining cap with new? These parts eventually wear out, with the first symptom being bad angularity.
Can you show some pics of the cuts you are describing?
When you bought your table did Arclight provide you with a couple CD's. If so one CD has lots of helpful tutorials on it. It has probably 10 or so tutorials dealing in length with plasma cutters from a-z. There is a lot to watch and digest but, I have found these tutorials as well as those done by Scott @ Arclight in their shop very helpful. As you probably already know Scott @ Arclight is nearly always available if the tutorials don't help. Try the tutorials. There is a wealth of information in them.
Best of luck,
Metalworx Fabricators
Arclight Pro 9600
Hypertherm Powermax 45
Best of luck,
Arclight Pro 9600
ArcLight Dynamics
ArcLight Dynamics
Change the retaining cap. Seen it before but don't know why it happens.
Actually just happened yesterday. New nozzle and electrode, and still getting an angled cut that is most noticeable on .8125" holes in .500 mild steel. Changed the swirl ring and no joy. Changed the retaining cap, problem solved.
Victor Simonis
Grey Forest MetalCraft
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
Stout wrote:Change the retaining cap. Seen it before but don't know why it happens.
Awesome, thanks.
I ordered all new front end consumables for my torch.
This has been driving me nuts and it's to the point that I can't even cut parts now because no combination of my current consumables will correct it.
I've gone from cutting parts like this;
To cutting parts like this;
I would guess with the extra squeeze the shield makes, if damaged it would show right up in cut quality. The 65 amp consumables normally do a excellent job on 0.500 MS .. Looked at a ton of it my friend cut on his table.. Paul, be sure to post if the fix is in...
PS-nice work as always..
UPDATE:
Ok, so far I am happy to report that changing out the retaining cap seems to have solved the problem.
I just cut some 3/16" HRPO and it cut great.
I also cut a piece of 3/8" HRS and it was probably the best cut I've ever had on that thickness.
I still don't know what would/could go wrong with the retaining cap to warrant replacement? There is no damage, plugged orifices, or signs of wear that I can see???
Either way, it's a relatively cheap fix seeing as how I got a year of cutting out of the first cap. Thanks for the tip Stout. I owe you one.
Here are the 3/16" parts. They are only 1.5" x 2"
And the 3/8". It is 13.625 in DIA
Just sharing the joy. Would you mind if I asked what amperage and speed you used to cut those little parts? I would really like to have the file so I can compare my machine to those very nice results. And would you mind sharing a picture of the back side?ZTFab wrote:UPDATE:
Victor Simonis
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
The retaining cap on Hypertherm Powermax systems over time can wear to a point that cut quality changes. It has critically machined air passages that meter the shield air flow.....the shield injects air radially around the plasma arc to improved energy density and edge squareness. The cap also helps to hold the nozzle, electrode and shield in concentric alignment.....so wear from a lot of use can change the required concentricity....dramatically affecting cut quality.
The cap on my (almost) four year old Powermax85 torch is the original, however I likely put a lot kless hours on it as compared to most...
Jim Colt
Jim Colt
Jim,
I'm using the Duramax MRT on my PM1250. When I change consumables I always turn on the air and put my hand under the torch to avoid splashing water. I recently noticed that air is coming out of the torch body between the retaining cap the torch body. What is the purpose of this escaping air?
Victor Simonis
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
