Want to shrink a 90 degree triangle to an 80 degree.
Is this possible? I have a gusset with a design on it but they are looking for an 80 degree instead of a 90 degree. Is there a way to reshape it like that?
Re: Want to shrink a 90 degree triangle to an 80 degree.
Not sure of the correct way, but I would think you can draw 2 lines on horiz one vert and turn them 80 degrees.
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- CNCCAJUN
This should give you what you need. Just size it . . .
- Attachments
- 80 Degree Gusset.dxf
- (200.71 KiB) Downloaded 94 times
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Thanks but I wasn't clear.... I have a pretty detailed 90 degree spiderweb gusset and I'd like to somehow shrink it to 80 degrees without having to redo everything. Not sure if this can be done with what I have.
