How to find cut inches on Torchmate?
Torchmates software related questions and tips can be posted here
cola78
Post by cola78 »
I have a torchmate,and I am trying to find the cut inches of a file . Can someone help me out with this?
Thank you
RC
fitzy
Re: how to find cut inches?
Post by fitzy »
I also run torchmate and don't know where on the program to find it but if you send it to the cutting software and select the speed to cut then multiply the ipm with the estimated time it should give you a rough idea how many cut inches it is
hope this helps
-fitzy-
-fitzy-
It ain't braggen if you can back it up!
blkbob
Re: How to find cut inches on Torchmate?
Post by blkbob »
On Pirate4x4.com Torchmate has it's own forum for all of us who have bought tables. You might want to sign up and post your question their. A lot of knowledge and hints on this forum.
G
jmsrbrt
Post by jmsrbrt »
cola78 wrote:I have a torchmate,and I am trying to find the cut inches of a file . Can someone help me out with this?
Thank you
RC
The other posted was right on...multiply your IPM speed by the time to cut the file, i.e, cutting at 60 inches per minute times 5 minutes equals 300 inches of cut. Don't forget your pierces if you are trying to figure out how long your consumables last.
kbenz
Post by kbenz »
Thank you
RC
if your trying to quote a job how do you know how long it takes to cut ?
jmsrbrt
Post by jmsrbrt »
Are you using the TM cutting program? At the bottom, middle, is the time it takes to cut the file you have open. ;)
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
jmsrbrt
Post by jmsrbrt »
Left of the Start/Reset buttons, and it's labled RUN TIME.
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
kbenz
Post by kbenz »
jmsrbrt wrote:Left of the Start/Reset buttons, and it's labled RUN TIME.
mine shows the program(gcode?) there
jmsrbrt
Post by jmsrbrt »
Would it be possible for you to do a screen shot and send it to me? jmsrbrt at gmail dot com
Just in case, hit your PRINT SCREEN button and then open your PAINT program where you can open what you just saved.
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
kbenz
Post by kbenz »
jmsrbrt wrote:Would it be possible for you to do a screen shot and send it to me? jmsrbrt at gmail dot com
sent it, thanks
kbenz
Post by kbenz »
to jmsrbrt,
thanks for the help
