NEW VACUUM SYSTEM
steelcutter
NEW VACUUM SYSTEM
Post by steelcutter »
THIS HOPPER SYSTEM IS ALL ALUM.
IF ANYONE NEEDS ANY INFO LET ME KNOW.
weldor2005
Re: NEW VACUUM SYSTEM
Post by weldor2005 »
I'm looking and trying to make sense of the second picture, it appears to have a piece of Al that would hinder a lot of the vacuum from the chute design. Is this also a water table and the hole patterns are the fill/drain?
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
steelcutter
THIS IS NOT A WATER TABLE. I WOUND UP CUTTING A 12'' HOLE IN THE MIDDLE OF THE SHEET FOR MORE FLOW. I HAVE 2 4'' PORTS ON THE BOTTOM WITH 2 VACUUM SYSTEMS WITH REMOTE KEY CHAIN SWITCHES..
chrisj380
Post by chrisj380 »
Hi steelcutter, It looks like maybe this system you have pumping into drum? Is this a contained system or is it vented outside? I'm looking for something like this that can be self contained in a room to cut down on dust. If this is still working great for you i would love some info on how to build one.
Thanks, Chris
