Sheetcam thc on/off
Little Leonard
Sheetcam thc on/off
Post by Little Leonard »
I've just now start to use my thc and need to know how to cut it off when I'm cutting small holes any help would be great.
4x8 Precison plasma table
Candcnc
Sheetcam,Mach3
TD cutmaster 82
rikduk
Re: Sheetcam thc on/off
Post by rikduk »
on: M102
off: M101
grindergary
Post by grindergary »
Are these on off codes for CandCNC controller, on:m102 and M101 for off?
What post processor are you using?
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
rikduk
Post by rikduk »
I use these codes to turn thc on/off before holes, haven't tried it on corners.
post is MP1000-thc
i have a Bulltear 5x10 table
sheetcam
mach3
rikduk
Post by rikduk »
Yes, Im using candcnc electronics
grindergary
Awesome, Thank you.
Now I can try that.
Gary
Sheetcam, Mach 3
BTA Plasma
Post by BTA Plasma »
rikduk wrote:I use these codes to turn thc on/off before holes, haven't tried it on corners.
post is MP1000-thc
sheetcam
mach3
You wont need it in corners. There is a feature called ANTI-DIVE which stops THC from controlling the Z axis when the feedrate drops below a certain point. 60% is where it is set at in stock form.
rikduk
Post by rikduk »
Sorry, i should have been more precise,
i was referring to the cutting rules in sheetcam, where you can turn off thc, slow down
for corners or small radius, then thc back on.
If im right, when you turn on/off thc while moving, there is a slight pause in movement.
Like i said, i havent tried it with corners yet, just holes.
rikduk
Post by rikduk »
By the way, thanks for the fast replies, Matt (Bulltear plasma tables)
grindergary
Having problems. Maybe you know what i'm doing wrong.
Set code snippit to M102 THC on
M101THC off
Set rule as holes, 1.5 dia slow to 60%, set code thc off, end code thc on.
I have a plate with 8 holes and outside square. When I run g code, goes to first hole, runs and shuts thc off, end of cut turns thc on. next hole thc doesn't shut off driving head into plate. I was watching it closely so was ready to stop it before any damage.
Any idea what I am doing wrong. Going to watch videos online again.
Gary
Sheetcam, Mach 3
rikduk
Post by rikduk »
Were gonna need a little more info.
screen shot with your rules in sheetcam, or what your g code looks like.
grindergary
Won't let me post the file.
Thanks for your help
Gary
N0010 (Filename: AF1.tap)
N0020 (Post processor: MP1000-THC.scpost)
N0030 (Date: 09/03/2014)
N0040 G20 (Units: Inches)
N0050 G53 G90 G40
N0060 F1
N0070 (Part: AF1)
N0080 (Operation: Outside Offset, CAD, T9: 1/2 65A)
N0090 M06 T9 F30 (1/2 65A)
N0100 G00 X2.5859 Y1.4198
N0110 Z0.1800
N0120 G28.1 Z0.12
N0130 G92 Z0.0
N0140 G00 Z0.0800
N0150 G92 Z0.0
N0160 G00 Z0.1800
N0170 M03
N0180 G04 P1.2
N0190 G01 Z0.0600 F10.0
N0200 M101
N0210 G03 X2.4259 Y1.2598 I0.0000 J-0.1600 F18.0
N0220 I0.2906 J0.0000
N0230 X2.4429 Y1.1618 I0.2906 J0.0000
N0240 M102
N0250 M05
N0260 G00 Z0.5000
N0270 X0.9717 Y2.7584
N0280 Z0.1800
N0290 G28.1 Z0.12
N0300 G92 Z0.0
N0310 G00 Z0.0800
N0320 G92 Z0.0
N0330 G00 Z0.1800
N0340 M03
N0350 G04 P1.2
N0360 G01 Z0.0600 F10.0
N0370 M101
N0380 G03 X0.8117 Y2.5984 I0.0000 J-0.1600 F18.0
N0390 I0.2906 J0.0000
N0400 X0.8288 Y2.5004 I0.2906 J0.0000
N0410 M102
N0420 M05
N0430 G00 Z0.5000
N0440 X0.9717 Y6.9317
N0450 Z0.1800
N0460 G28.1 Z0.12
N0470 G92 Z0.0
N0480 G00 Z0.0800
N0490 G92 Z0.0
N0500 G00 Z0.1800
N0510 M03
N0520 G04 P1.2
N0530 G01 Z0.0600 F10.0
N0540 M101
N0550 G03 X0.8117 Y6.7717 I0.0000 J-0.1600 F18.0
N0560 I0.2906 J0.0000
N0570 X0.8288 Y6.6736 I0.2906 J0.0000
N0580 M102
N0590 M05
N0600 G00 Z0.5000
N0610 X2.5859 Y8.2702
N0620 Z0.1800
N0630 G28.1 Z0.12
N0640 G92 Z0.0
N0650 G00 Z0.0800
N0660 G92 Z0.0
N0670 G00 Z0.1800
N0680 M03
N0690 G04 P1.2
N0700 G01 Z0.0600 F10.0
N0710 M101
N0720 G03 X2.4259 Y8.1102 I0.0000 J-0.1600 F18.0
N0730 I0.2906 J0.0000
N0740 X2.4429 Y8.0122 I0.2906 J0.0000
N0750 M102
N0760 M05
N0770 G00 Z0.5000
N0780 X6.7591 Y8.2702
N0790 Z0.1800
N0800 G28.1 Z0.12
N0810 G92 Z0.0
N0820 G00 Z0.0800
N0830 G92 Z0.0
N0840 G00 Z0.1800
N0850 M03
N0860 G04 P1.2
N0870 G01 Z0.0600 F10.0
N0880 M101
N0890 G03 X6.5991 Y8.1102 I0.0000 J-0.1600 F18.0
N0900 I0.2906 J0.0000
N0910 X6.6162 Y8.0122 I0.2906 J0.0000
N0920 M102
N0930 M05
N0940 G00 Z0.5000
N0950 X8.3733 Y6.9317
N0960 Z0.1800
N0970 G28.1 Z0.12
N0980 G92 Z0.0
N0990 G00 Z0.0800
N1000 G92 Z0.0
N1010 G00 Z0.1800
N1020 M03
N1030 G04 P1.2
N1040 G01 Z0.0600 F10.0
N1050 M101
N1060 G03 X8.2133 Y6.7717 I0.0000 J-0.1600 F18.0
N1070 I0.2906 J0.0000
N1080 X8.2303 Y6.6736 I0.2906 J0.0000
N1090 M102
N1100 M05
N1110 G00 Z0.5000
N1120 X8.3733 Y2.7584
N1130 Z0.1800
N1140 G28.1 Z0.12
N1150 G92 Z0.0
N1160 G00 Z0.0800
N1170 G92 Z0.0
N1180 G00 Z0.1800
N1190 M03
N1200 G04 P1.2
N1210 G01 Z0.0600 F10.0
N1220 M101
N1230 G03 X8.2133 Y2.5984 I0.0000 J-0.1600 F18.0
N1240 I0.2906 J0.0000
N1250 X8.2303 Y2.5004 I0.2906 J0.0000
N1260 M102
N1270 M05
N1280 G00 Z0.5000
N1290 X6.7591 Y1.4198
N1300 Z0.1800
N1310 G28.1 Z0.12
N1320 G92 Z0.0
N1330 G00 Z0.0800
N1340 G92 Z0.0
N1350 G00 Z0.1800
N1360 M03
N1370 G04 P1.2
N1380 G01 Z0.0600 F10.0
N1390 M101
N1400 G03 X6.5991 Y1.2598 I0.0000 J-0.1600 F18.0
N1410 I0.2906 J0.0000
N1420 X6.6162 Y1.1618 I0.2906 J0.0000
N1430 M102
N1440 M05
N1450 G00 Z0.5000
N1460 X9.4463 Y9.5741
N1470 Z0.1800
N1480 G28.1 Z0.12
N1490 G92 Z0.0
N1500 G00 Z0.0800
N1510 G92 Z0.0
N1520 G00 Z0.1800
N1530 M03
N1540 G04 P1.2
N1550 G01 Z0.0600 F10.0
N1560 G03 X9.6063 Y9.4141 I0.1600 J0.0000 F30.0
N1570 G02 X9.6503 Y9.3701 I0.0000 J-0.0440
N1580 G01 Y0.0000
N1590 G02 X9.6063 Y-0.0440 I-0.0440 J0.0000
N1600 G01 X0.0000
N1610 G02 X-0.0440 Y0.0000 I0.0000 J0.0440
N1620 G01 Y9.3701
N1630 G02 X0.0000 Y9.4141 I0.0440 J0.0000
N1640 G01 X9.6063
N1650 G02 X9.6503 Y9.3701 I0.0000 J-0.0440
N1660 G01 Y9.3392
N1670 M05
N1680 G00 Z0.5000
N1690 X0.0000 Y0.0000
N1700 M05 M30
Sheetcam, Mach 3
grindergary
Emailed Les at Sheetcam.
He said the code looked good. He questioned whether the I was using the right code snip.
He also asked if Mach was set up to use those codes? Don't know. Anyone have a way to see if the code is in Mach?
for all your help,
Gary
Sheetcam, Mach 3
SeanP
Post by SeanP »
I use:
S10 (DTHC OFF)
S20 (DTHC-ON)
CandCNC bladerunner system, Mach 3
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
grindergary
SeanP wrote:I use:
S10 (DTHC OFF)
S20 (DTHC-ON)
Thanks SeanP,
I will see if I can find out what is on my system. I guess I may need to upgrade Mach.
Thanks for the information.
Gary
Sheetcam, Mach 3
I Lean
Post by I Lean »
The M101/102 macros weren't in my Mach3 by default, I had to install them separately. (which means copy/paste the files into the right folder) Once I did that, it all magically worked. :)
I don't try to turn the THC off during a cut, or for corners or anything--I just set all my holes up on their own layer, make a separate operation for them, and use the M codes to turn the THC off before cutting them, and back on after.
So my order of operations looks something like:
Insert code M101
Inside offset, holes layer, with my "slow hole" tool (50%-60% normal feedrate for that material)
Insert code M102
Outside offset, regular tool, for the rest of the part.
Works great for me! :mrgreen:
grindergary
[quote="I Lean"]The M101/102 macros weren't in my Mach3 by default, I had to install them separately. (which means copy/paste the files into the right folder) Once I did that, it all magically worked. :)
Where would I find these M code macros. I am guessing they would go into the macro folder in mach.
Thanks for your reply,
Gary
Sheetcam, Mach 3
I Lean
Post by I Lean »
grindergary wrote: Where would I find these M code macros. I am guessing they would go into the macro folder in mach.
Gary
I got them from the CandCNC Support Yahoo group, I don't think that's still active though. I'll just attach them here :)
grindergary
I Lean,
Thank you so much!
Gary
Sheetcam, Mach 3
rikduk
Post by rikduk »
SeanP, is your system very recent?
Did you have to add or change something to use s10/s20 codes?
are you using mp3000-dthc post?
thank you
Return to “SheetCam”
