cutting 6mm stainless with powermax 30
plascutart
Post by plascutart »
Can anyone recommend the settings for cutting 6mm (1/4'') stainless plate with with a powermax 30 on a DHC2.
First time try and would like a close starting point.
Or would I use the same settings & speed as mild steel?
Thankyou
plascutart
Re: cutting 6mm stainless with powermax 30
Post by jimcolt »
Here is the chart for steel cutting, and also the stainless chart. These charts are for mechanized cutting with a Powermax45 using the Powermax30 consumables. They are only recommended for cutting up to .135" thick.
If you need to cut 1/4" stainless with the 30.....I would recommend experimenting a bit. Pierce height should be about .150" and cut height at about .06". Try cutting at about 18 to 20 ipm, and increase the speed 2ipm at a time to determine best speed.
The Powermax30 is designed as a hand cutting system.....so when it it used for mechanized cutting we typically downgrade it's thickness capability so you are less likely to exceed the duty cycle.
30ampstainless cut chart.jpg (51.18 KiB) Viewed 894 times
plascutart
Thank you Jim, will try these settings
regards
plascutart
