What to correct this ?
Sampson Jones
Post by Sampson Jones »
Hypertherm powermax 45 all settings per hypertherm manual, fresh consumeables
16 ga steel
350 imp
Pierce delay 0
Mach settings , I may say these two backwards ,don't remember acelleration 2400 ,velocity 45
Looks like at least two problems , the letters were supposed to be square block type
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
OTHill
Re: What to correct this ?
Post by OTHill »
Looks like some serious play in your drive somewhere.
kb3gun
Post by kb3gun »
I agree with OTHill. It also looks like you're starting the lead-in (pierce) in good material instead. The path might not be made correctly or female cut path was selected instead of male cut path.
-Smitty
Torchmate 4X4 Growth Series w/AVHC
Hypertherm PM45 w/ Machine Torch
Miller Syncrowave 210 TIG
I Lean
Post by I Lean »
Lower feed rate will make a big difference I'm sure. Many (most?) tables can't functionally cut at 350 IPM with any quality. I try to keep mine under 150 or so generally.
Post by jimcolt »
backlash in the drive is what it looks like to me.
Jim Colt
Sampson Jones
Found one problem , loose pinion gear on one of the Y motors
CandCNC electronics
Command Lineux
Super z 2
cindy carlisle
Post by cindy carlisle »
Sure looks like something is loose......does it do it when cutting a straight line as well?
Cindy
http://www.trucutcnc.com
615-290-6260
abmetal
Post by abmetal »
Looks like several things. To start with, what font is it? We use a font that looks similar.
Leeway
Post by Leeway »
I think your velocity @ 2400 IPM is way too high. Mine is R&P and is set to about 300 IPM. If metric, then I don't know off hand what that might be. My acceleration is 50, so you are close to my settings there.
Lee
