DIPPING
abmetal
DIPPING
Post by abmetal »
Is anybody familiar with the type of paint used to coat metal by the dipping process? I've searched different sites but haven't come up with the correct stuff.
Thanks.
Allen
tnbndr
Re: DIPPING
Post by tnbndr »
Check out the links in this post.
http://plasmaspider.com/viewtopic.php?f=84&t=9146
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
abmetal
Re: DIPPING
Post by abmetal »
I'm familiar with that process but that's not what I'm looking for. Manufacturers use this process, though not as much since powdercoating became popular, to dip coat their parts on the assembly line. The paint is formulated to eliminate runs, drips. Automotive manufacturers used to use it and maybe still do.
Allen
CNCCAJUN
Re: DIPPING
Post by CNCCAJUN »
If you decide to go with a "DIP TANK" with any type of paint, chemical, etc . . . . even a wash or neutralizing tank.....
DO NOT LET ANY PART OF THE TANK (bottom, walls, etc...) TOUCH OR GO BENEATH THE GROUND.
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
