corel draw home/student
is this powerful enough to edit dxf/svg files?
I want to edit and remove lines from existing files
I want to be able to make names weld and bend them
there is a tutorial service for corel draw ( Lynda's or lydias) $25-37 amonth
I have inkscape but don't know how to use it
any advise would be apreciated
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
- Larry83301
Re: corel draw home/student
abmagrum wrote:is this powerful enough to edit dxf/svg files?
Check out this blog - - http://inkscapedxf.blogspot.com/
Everything you ever wanted to know about Inkscape.
Also Switcher on CNC ZONE has several posts dealing with the ins and outs of Inkscape. All FREE
Search Inkscape or Switcher posts!
CorelDraw x3 and x6 will import and allow editing of .dxf and .svg files. It's all I use for drawing and modifying files for cutting. Very easy to use and a fantastic user group. Plenty of videos on YouTube if you need them. Adobe Illustrator is what my artists typically use. They just send me a .pdf which I import into CD x6. All of my output is export to .dxf for import into TurboNest. CD is less than $100 on Ebay.abmagrum wrote:is this powerful enough to edit dxf/svg files?
I wouldn't get the student version. I believe all of your printed output will have a "Student" label on the border. Makes for a really bad presentation to clients.
Victor Simonis
Grey Forest MetalCraft
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
I think you will also find student versions are not upgradable.
Murray
Murray
Here is the best deal I have found on X6, it is the full version but you have to qualify as student to purchase.
http://www.journeyed.com/item/Corel/Cor ... te/1534577
Cool,
Thanks, Mountain home.
Is this a download? or hard disk? thanks.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
if you google the part number it is the education versionMountain Home wrote:Here is the best deal I have found on X6, it is the full version but you have to qualify as student to purchase.
sign torch
will that education version work?
mostly what I want to be able to do is add or cut a few lines, and make names and welcome. to add to youre graphics
as soon as I learn how to do fonts I will be ready to buy yours and jasons artwork.
do you think corel draw would be easier to learn then inkscape?
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
It is a disk.abmagrum wrote:Cool,
Gary, you are right, I looked on the case and it says "education edition". I don't know what is different about it. It will import and export dfx files and it does not mark "student" on anything.
THANKS, MOUNTAIN HOME
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
several amazon reviewers are not too happy with home and student
I keep hearing that it does not have vba or macros, which would preclude being able to use addons like dxftool
it lacks some customization features, print preview and preflight, may have a banner across the top that says not for commercial use, may be 32 bit only, etc....
Gary, I am posting a couple of screen shots that may answer a couple of questions. I am not trying to sell anyone on this version, but if there is a feature that anyone wants to know if it includes I will look for them and try to help. I read some of the reviews and some of the info is not correct, for example one reviewer said the toolbar icons could not be enlarged, I checked and they can.
