PhotoShop Elements....
toymaker2
Post by toymaker2 »
Are there any flie types that can go straight from PhotoShop Elements to the Plasma cutting program, and still be able to cut out what was drawn in PhotoShop Elements?
Right now, I have a problem where I have to draw pictures in PhotShop Elements because that is where my internet source is. Then, I have to save it as a Bitmap in PhotShop Elements, and then go over to another computer. I then open it up in SignLab and redraw it. Then, I save it as a DXF file, and then take it to the Plasma cutting program....
Is there a quicker way to do this, by passing the SignLab computer set?
fab-man
Re: PhotoShop Elements....
Post by fab-man »
I may be wrong but I don't think you will ever be able to accomplish what you need with PhotoShop. I would save your bitmap image to a flash drive (memory stick) then simply open that up on your other pc and do your vector conversion in SignLab.
Fab-Man
