SJDrummond's CNC Plasma Wiring Diagram
SJDrummond
Re: SJDrummond's CNC Plasma Wiring Diagram
Post by SJDrummond »
Hi Rod,
Yep you were absolutely bang on the money. Thank you!!
I disconnected the THCAD Shield Pin to DC Ground, and that seemed to have solved it!
Managed to successfully cut a funny sign for a friends bar this evening!! (Image attached).
Can’t thank you enough Rod.
All the best,
Sean
Rodw
Post by Rodw »
Awesome you got it done and you are cutting!
SJDrummond
Hi all,
Apologies for not being on the forum in a while. I have fixed a couple of errors on the wiring diagram and will post the latest version below.
Changes:
- Removed the GND connection from the input side of the THCAD-5.
- I had the status LEDs connected all wrong, so have fixed those (I think). If anybody could take a look and confirm that would be amazing.
- Added a laser pointer connection.
All the best,
Sean
CNC Plasma Wiring Diagram V1.pdf
weldguy
Post by weldguy »
Nice diagram! Well done and glad to hear everything is working out :Like
