X7 Coreldraw smooth tool - Tiger trace
SeanP
Post by SeanP »
Just another quick look at the Smooth tool in X7
Very helpfull at cleaning up traced files or hand tracing for that matter.
See video link here - http://youtu.be/05u07O-VfAI
Tiger trace.jpg (50.02 KiB) Viewed 1583 times
Tiger.dxf
(264.21 KiB) Downloaded 102 times
Tiger.dxf
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
AnotherDano
Re: X7 Coreldraw smooth tool - Tiger trace
Post by AnotherDano »
Thanks Sean.
Dano
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
Cheers Sean,
looks like a very efficient and useful tool. I wonder if the reduce nodes tool in X5 can achieve the same thing but with a lot more work.
You got me thinking about X7 now :D
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
SeanP
Post by SeanP »
beefy wrote:Cheers Sean,
:D
Keith.
Reduce nodes does work similar, but smooth will take off sharp corners and straighten dodgy lines/curves better I think, very little about it online.
Powermax XP45
Table build gallery
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
SeanP wrote:Reduce nodes does work similar, but smooth will take off sharp corners and straighten dodgy lines/curves better I think, very little about it online.
I really like the bit about taking off sharp corners. I've done that manually quite a few times. What are you doing to me Sean, now I really want X7.
Thanks for the info.
Keith
LinuxCNC
Coreldraw 2019
WyoGreen
Post by WyoGreen »
Sean,
I enjoyed your video on the smooth tool, which I use a lot. One thing that I noticed you do was to change the size of the selection circle on the fly by moving the + center to the edge and dragging the selection circle to a different size. I haven't figured out how you did that, and can't find anything online about that. So, how did you do that?
Router
Laser
SeanP
Post by SeanP »
Good stuff, thanks.
It's surprising there is very little about using the smooth tool, have a look on here, you can use the same shortcuts for some of the other tools in that group as well.
http://community.coreldraw.com/share/b/ ... ol-options
Powermax XP45
Table build gallery
WyoGreen
Post by WyoGreen »
Thanks Sean,
I figured it had something to do with the shift, alt or ctrl keys, just couldn't get the right combo together. That tip makes using the smooth tool a lot easier. Works pretty good with the Eraser tool also.
Router
Laser
srp
Post by srp »
It might behave like Photo paint. Hold down the shift key and with the mouse left click hold and move the mouse north and south.
