Paint Booth - Bench Style
- CNCCAJUN
I am in the process of designing & building a Bench Style Paint Booth. & Paint Room.
Looking for input, ideas, etc. . . .
Pictures attached of a booth are only to give an idea of what I am looking to build from a style standpoint.
I am not building my own to save dollars, but to get a booth more applicable to what we are doing, ?painting pieces of plasma cut sheet metal?.
What I have in mind is as described below:
* Constructed of 3/4? plywood & standard frame material. (2X4, 2X2, etc. . .) suggestions?
* Downdraft through real paint booth exhaust filters to the outside. (now I?m legal)
* Downdraft opening 60" wide X 40" deep - will accept ( 6 ) 20? X 20? filters.
* Dwyer manometer to monitor filter loading.
* Filters supported by angle iron grid & 2X4 Hog Wire.
* Access (front) opening 60" wide X 42" high.
* Grainger 7F930 - 12" Tubeaxial Fan with 3/4HP motor ? 2126 CFM @ 0.50? SP
* Fan will be mounted in rear of booth @ bottom connected to plenum sized 44? deep X 60? wide X 36? high.
* Thinking 2 or 3 horizontal 1" pipes running side to side @ top to hang projects to be painted from. (ideas?)
* Large gauge wire grid 40? X 60? for support of non-suspended projects.
* Lighting - (4) tube fluorescent bulb fixture located on exterior of top.
* Light will pass through recessed plate glass to keep light out of paint stream.
* Paint Booth will be located in a 7' X 8.5' room with filters for make-up / fresh air intake.
* 20" fan with filter in room wall to assist with make-up/fresh air intake.
Already received some excellent input from Marty . . .
Thanks in advance,
Steve in Louisiana
Thanks in advance,
Steve in Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: Paint Booth - Bench Style
Looks like a good plan. Not sure where you are getting a tubeaxial fan with motor for $320, but jump on that deal!
- CNCCAJUN
eBay . . . are you looking for one?Cracker Red wrote:Looks like a good plan. Not sure where you are getting a tubeaxial fan with motor for $320, but jump on that deal!
It seems this particular 12" is being surplused out. Grainger tells me the model suffix designates an O.E.M. but identical to the rest in with the same model number.
It will be here tomorrow, hope it is not a P.O.S. . . . . supposed to be new in the box.
Sorry for the mislead, this was without motor. $293.00 with shipping.
I have a NIB Baldor - TEFC - 56 Frame - 3/4HP sitting here.
It is the same motor the OEM was using.
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- CNCCAJUN
Received the fan, tested it . . . works perfect . . .
Where do you guys that paint, clear coat or rattle can do it?
It is cold here now and humidity goes up and down.
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- _Ogre
why not build a plenum and filter rack in the end of the 7x8.5 room for exhaust?
paint booth to me means filter inlet air (which you have) and exhaust fan
not sure what your going to accomplish with the additional box
an ogre smiley how cool!
- CNCCAJUN
_Ogre wrote:why not build a plenum and filter rack in the end of the 7x8.5 room for exhaust?
Funny you say that, I came to the same conclusion last night when checking layout space . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- steelfx
Steve,
Have you considered Uni-Strut & custom, plasma-cut hangers instead of the pipe & wire method?
Bill
Bill
- CNCCAJUN
Great idea . . . Piece of UNISTRUT 60" long and make hangers that would accept wire or make custom holders that would be the actual hanger.steelfx wrote:Steve,
Bill
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- steelfx
Here's the hangers I use, but you may have to tweak 'em a little.
Or, you may come up with an even better way! These work great & I like them a little tight.
I can't recall if I added a torch offset on these or not.
Haven't had to cut any in 5-6 yrs. I cut about 48 of 'em & still have most of 'em.
thanks!
Bill
thanks!
Bill
- CNCCAJUN
Thank you very much . . . based on the dimensions I assume you are running low profile uni-strut.
Steve . . . a fellow Dynatorch Guy . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- steelfx
Actually, no. The unistrut I use is basically square. I don't have access to it right now, but it's 1-1/2" or 1-5/8", as I recall. The low-pro unistrut would be okay, but not as strong. My rack is 10' wide with the uni-strut at approx. 5' off the ground.CNCCAJUN wrote:Thank you very much . . . based on the dimensions I assume you are running low profile uni-strut.
I've hung 2 - 30" X 60" X 7awg. panels from it with no sag and no trouble. Two hangers per panel.
Bill
- _Ogre
great minds think alike?CNCCAJUN wrote:Funny you say that, I came to the same conclusion last night when checking layout space . . .
we have a bunch of various paint hooks of various lengths from 4'' to 18''
they are cheap on ebay too
- CNCCAJUN
Do you use UNI-Strut like SteelFX with your hooks also . . . or a round rod (pipe)?_Ogre wrote:great minds think alike?CNCCAJUN wrote:Funny you say that, I came to the same conclusion last night when checking layout space . . .
I am thinking the UNI-Strut may eliminate accidental "unhooks" as you could have with a pipe . . .
Or combine a Uni-Strut hanger like SteelFX has designed with the hooks you are using . . .
uuuuuuum!
Thanks everybody,
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- _Ogre
now your just going to be jealous...
full truck size paint booth with a motorized conveyor 20 ft in the booth to 20 ft out of the booth
we can hang a full car in parts on it; paint half, rotate out and paint the other half
we use to do a lot of electrical control boxes when the economy was better, now we're too busy for that market
we also have a hydrographics area with eyelets on the wall.
2 hooks hang uni-strut across the area with more hooks on the uni-strut, the uni-strut can be removed in seconds
i wouldn't hang anything permanent
