Help with trace
grindergary
Help with trace
Post by grindergary »
I took a scroll pattern from google search and did a trace. Moved vector away to one side highlighted lines and removed all color. I then took the vector over top of the original to remove extra lines and double line. I don't know what I did then but I cannot move the vector from the original.I have attached the original and the pattern I was trying to make.
Any help to let me know what I did wrong would be greatly appreciated. This has not happened before.
I tried to ungroup but no go.
I wanted to make a corner bracket so I was going to split it on a 45 degree angle.
Thank you in advance
Gary
Original jpeg
Original jpeg
Original jpeg
scroll.cmx
Scroll pattern
(475.73 KiB) Downloaded 85 times
scroll.cmx
Scroll pattern
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
wilber
Re: Help with trace
Post by wilber »
i norm just import, trace, delete import and save as dxf.
I am not sure on the program you used. I use vcarve and aspire for tracing and drawing.
scroll.dxf
(711.36 KiB) Downloaded 107 times
scroll.dxf
grindergary
Re: Help with trace
wilber wrote:i norm just import, trace, delete import and save as dxf.
Thank you for the trace! I used Corel X6.
Normally I would do the same procedure you describe. When I did the trace, some of the curves were out of round so I placed the vector over the original to move the nodes to the correct position so the curves were smooth.
Thank you for the help.
gary
Sheetcam, Mach 3
wilber
Re: Help with trace
Post by wilber »
any time i can help just let me know
beefy
4.5 Star Member
4.5 Star Member
Re: Help with trace
Post by beefy »
I've got X5 but it wouldn't open the file.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
grindergary
Re: Help with trace
beefy wrote:I've got X5 but it wouldn't open the file.
Keith.
Keith,
I added a CDR file for you to see if it will open for you. If it does, see left side is colored from original under neath of vector.
I just can't figure out what I may have done.
I did re do the trace and it worked out pretty good. Wilber did one and mine looks close to the one he did.
Thanks for any suggestions,
Gary
scrollA.cdr
(573.89 KiB) Downloaded 97 times
scrollA.cdr
Sheetcam, Mach 3
beefy
4.5 Star Member
4.5 Star Member
Re: Help with trace
Post by beefy »
Sorry Gary,
that one wouldn't open in my X5 either. I was looking forward to seeing if I could figure it out too.
Keith.
LinuxCNC
Coreldraw 2019
