Exporting a 3d design to dxf
charlie chop
Post by charlie chop »
Howdy, I've got a 3d design that I need to break apart and export to dxf and sheetcam. I'm using vectorworks cad .
When I export it and bring up the file in sheetcam there is nothing there,
So is it even possible to export 3d or do I have to trace or redraw in 2d,
Any help appreciated
Cheers everybody
sodfarmer
Re: Exporting a 3d design to dxf
Post by sodfarmer »
I've never used vectorworks cad, but in Solidworks or Inventor you need to import the parts into your drawings and them save them as a dxf. It basically like you are doing a detailed drawing, just save as a dxf.
beefy
Post by beefy »
A 2d drawing is on one plane with X & Y co-ordinates. A 3d drawing represents a solid (e.g. SOLIDworks) object, has depth, sides or curved surfaces. It could be hollow on the inside, or have hundreds of flat surfaces on the outside. How do you get a 2D drawing of a coil spring for instance ?
In my 3D solid modelling software, to get a 2D drawing from a 3D object I have to know exactly what part of the object I want the 2d drawing of. I have to "project" that part of the 3d object to a new 2D plane, and only then do I have a 2D sketch of a particular view of my 3D object.
Unless a 3D cad program is very basic and automatically stores particular views, like front, back, top, bottom, left, right, I don't know if you can simply convert a 3D file to a 2D file.
You really need to get on a cad forum for your particular software and some of the "heavies" there may know a way to do it.
There is also 3D dxf I beleive and I think it's quite different to the 2D dxf that we deal with for our art files.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
mike 1948
Post by mike 1948 »
Return to “SheetCam”
