1/4" mild steel, how's this look?
Shane Warnick
Post by Shane Warnick »
New to this plasma cutting deal, cutting on a samson 5x10 with a hypertherm powermax 1250, T80M machine torch with snapcut breakaway holder. Clean dry air, cut this plate last night with 60 amp, 60 ipm, cut height .0625", kerf 0.070", pierces were @ 0.125", ohmic sensing with 60amp consumables. The edges are straight for the most part, very minimal bevel, mostly where there are radical changes in direction (sharp corners). The holes are 3/4" and measured 0.75" on the top side, 0.680" on the back side, so 70 thousandths bevel, or 35 thousandths per side. Dross on the backside was minimal, flaked right off with a scraper, no grinding was required, zero top side dross, only a small wisp, if that makes sense, that wiped off with my glove.
I experimented with several different amp settings and speeds using the hypertherm book as a starting point and adjusting based on dross and angularity. Finally settled on the above as it seemed to best quality of cut, then I cut this out.
I was just wondering if this is as good as is to be expected / normal (I realize it's not a lazer nor a waterjet) or if I should keep swinging and try to make it better. I don't want to waste steel and time chasing something that's not really attainable. I have attached a few pictures for reference.
So I ask you, oh wise and knowledgeable masses, what say you? Looks great? Meh, could be better, keep trying fat boy? Looks like you hit the middle, seen better, seen worse?
Thanks in advance for your time on this.
Shane
mdwalker
Re: 1/4" mild steel, how's this look?
Post by mdwalker »
The more important question is how does it look to you. From the pictures it looks pretty good, might could tweak it a little. If you see any issues with it you could point them out and somebody on here would be able to give you advice on whether that is acceptable or if something needs adjusted.
Danny
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
weldor2005
Post by weldor2005 »
Only thought would be that your dross is low speed dross, and you could have less by going a touch faster. This is reinforced by seeing that the profile of cut would suggest the plasma is going through the material at a 90? angle, and to get the faster less slow speed dross you should get an angle of about 30? lag from the torch, if that makes sense.
This is a very crude sketch...
Plasma Direction.PNG (10.88 KiB) Viewed 1952 times
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
For best quality you should always use the smallest nozzles that will cut a given thickness. The 1250 cut charts list quarter inch steel with the 40 amp nozzles.
If you are happy to spend some more money, you could get the Duramax machine torch. Many people rave over the increased cut quality as compared to the original 1250 torches.
If the dross in your pictures is very difficult to remove (like it's welded on) then that is high speed dross, so lowering the cut speed could help at least with that part of things.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
JJsCustomDesigns
Post by JJsCustomDesigns »
with my 1250 i was running 40amp tips @ 55ipm and had great results on 1/4". I didnt have the duramax torch but i had a T80M machine torch.
PM me with details
1. The dross indicates too slow, or incorrect height. (Height must be .060"). If the height is correct, increase speed until dross is gone.
2. Better cuts on 1/4" wiill be achieved using the 40 amps shielded consumables. Better edge angularity and smoother edges, less taper in holes. Again, height is critical, start at book specs on speed, slower is squarer, but higher chance of dross.
Overall, looks pretty good!
Jim Colt Hypertherm
Shane Warnick wrote:New to this plasma cutting deal, cutting on a samson 5x10 with a hypertherm powermax 1250, T80M machine torch with snapcut breakaway holder. Clean dry air, cut this plate last night with 60 amp, 60 ipm, cut height .0625", kerf 0.070", pierces were @ 0.125", ohmic sensing with 60amp consumables. The edges are straight for the most part, very minimal bevel, mostly where there are radical changes in direction (sharp corners). The holes are 3/4" and measured 0.75" on the top side, 0.680" on the back side, so 70 thousandths bevel, or 35 thousandths per side. Dross on the backside was minimal, flaked right off with a scraper, no grinding was required, zero top side dross, only a small wisp, if that makes sense, that wiped off with my glove.
Shane
Shane Warnick
Thanks everyone for the input, I will tweak on it a little and see what happens. Thanks again for your time. Stay safe
Shane
