Cut Test G-Code
Capstone
Cut Test G-Code
Post by Capstone »
I'm looking for a .DXF that will test the cut quality without THC so I can baseline a Plasma Cutter that's not a HT or other common mfr.
Or Is this something that I have to create within Sheetcam instead from a bunch of straight lines?
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
Capstone
Re: Cut Test G-Code
Post by Capstone »
Has anyone seen anything like this?
Phil
CNC Metal Design
JD Squared 4x8
Gamelord
4.5 Star Member
4.5 Star Member
Re: Cut Test G-Code
Post by Gamelord »
Not really sure what you are asking for. Basically you should be able to use any DXF file for testing...but you can't test the quality of cut without actually cutting.....at least I have never heard of any way of doing this. Perhaps I am not understanding your question.
Capstone
Re: Cut Test G-Code
Post by Capstone »
Just a picture that has a few common shapes like circles and squares and lines. Then apply different tool settings to each grouping so that the speed/amperage could be evaluated all at once for cut quality
I am pretty sure I could create it myself, but I just figured that someone might have already done one a long time ago.
Phil
CNC Metal Design
JD Squared 4x8
DezertBlingMoto
Re: Cut Test G-Code
Post by DezertBlingMoto »
Torchmate has one but not sure if it is compatible with youre program set-up
Re: Cut Test G-Code
Here's one that we use at Hypertherm for 45 to 65 amp processes....it is a .dxf drawing so will need post processing with lead ins, kerf compensation cut direction, lead out, etc.
Jim Colt
XD_50A_MS.dxf
(146.9 KiB) Downloaded 249 times
XD_50A_MS.dxf
plain ol Bill
Re: Cut Test G-Code
Post by plain ol Bill »
Jim your .dxf file load at 4.8 inches x 4.2 inches - is that the correct size for the test plate? Going to give this a shot and see how it will cut with my brand new, shiny, never been used before Duramax machine torch on my 1250/.
plain ol Bill
Hypertherm 1250
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Re: Cut Test G-Code
Yes, sounds like the right size.
I have never cut that part....but it is used as a comparative samle for some processes in our development labs.
Jim
