Powermax 30 Consumables on a Powermax 45 machine torch
larrycameron44
Post by larrycameron44 »
Hi all, I for the first time in 3 years cut something different than 1.6mm plate or 0.5mm copper.
I was watching a video on making a meat cleaver and thought yeah. I have an old saw blade so I guessed a few settings and this is what happened!
I remember Jim Colt saying the other day that it is harder to control the bevel on thin stuff and easier on thick stuff. I sometimes have bevel on my 1.6mm but this 4.00 mm ex sawblade from a sawmill cut brilliant.
Only problem was I couldnt drill out the dam holes they are so hard now. tried cobalt and titanium bits but useless, any one got a plan?
Settings
50IPM
93 Volts
.4 sec pierce delay
30 amps (old consumables)
Cheers to Hypertherm!
NZ
SeanP
Re: Powermax 30 Consumables on a Powermax 45 machine torch
Post by SeanP »
That does look good, do you usually use the 30a parts on the 1.6mm plate? just wondering if you see much difference from the 45a consumables on that thickness with the taper?
I keep thinking of trying them myself.
Thanks for posting.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
weldor2005
Post by weldor2005 »
Those holes are not in a location that needs the steel to be hardened to much degree. I would run a flame over them and soften it up and then drill it with cobalt.
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
abmagrum
Post by abmagrum »
hit it with a die grinder, then drill
,its only hard on the outside,
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
larrycameron44
SeanP wrote:That does look good, do you usually use the 30a parts on the 1.6mm plate? just wondering if you see much difference from the 45a consumables on that thickness with the taper?
Thanks for posting.
Yeah I have been using the 30 amp for the last 3 years or so as my table has a top speed of 150ipm. Torchmate 2 x 4
It also makes a smaller kerf than the 45 amp as well.
The photo is of 100 butterflies at 25 gauge cut with the 30 amp consumables
NZ
larrycameron44
weldor2005 wrote:Those holes are not in a location that needs the steel to be hardened to much degree. I would run a flame over them and soften it up and then drill it with cobalt.
Are cheers that's a good plan too
NZ
SeanP
Post by SeanP »
Thanks Larry, good info.
NZ
Powermax XP45
Table build gallery
