explode
kbenz
explode
Post by kbenz »
is there a way to do the opposite? I have an exploded object that i would like to be unexploded. I am using the acad clone of draftsight
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
sodfarmer
Re: explode
Post by sodfarmer »
Use the pedit command. It will ask you select a polyline, select the multiple command and select the lines that you want to join. It should ask you to convert to polylines, select yes. Pick join. It will ask you the fuzz distance, I use the default which is 0.0000.Use this and you should have a polyline as long as the lines are connected.
John
kbenz
Re: explode
Post by kbenz »
I do good till i hit the fuzz? I'm not gettin that. here is a screen shot. thanks
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
sodfarmer
Re: explode
Post by sodfarmer »
Try changing the fuzz distance to .000. I have found that the default distance doesn't work with some files.
kbenz
Re: explode
Post by kbenz »
crap..........
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
