Cutting Thin Gauge Material
pdjcutandfab
Post by pdjcutandfab »
Wondering what the thinnest material is you've cut with your plasma table? Any tips? Thanks.
abmetal
Re: Cutting Thin Gauge Material
Post by abmetal »
I've cut 28ga. galvanized clean as a button.
Allen
26 gauge galvanized....beautiful! (Powermax85 running at 40 amps, 325 ipm)
Jim Colt
muzza
Post by muzza »
Cut some painting stencils from 0.45mm (which I think is about 26 or 28 gauge) zincaneal, had the speed cranked up to 8 metres per minute (about 315 ipm) and came out spot on.
Murray
GPM870
Post by GPM870 »
The thinnest I have cut is 31 gauge tin plate steel.
Powermax 85 45amp nozzle 325 ipm 25amps of power. Little hard on consumables but nice cut.
Powermax 85
Mach 3
4 x 4
burntables table
