I have been cutting some 16 gauge cold rolled steel with my hypertherm 1000 at 150 inches /min
and seem to have more slag on the bottom side of the cut than I think I should.
I'm using a plasmacam 4x4 table, clean dry air, using all hypertherm cut charts for finecut.
I'm wondering should I slow the speed down,or speed up to get less slag?
I'm sure some of you professionals can help me out. thanks in advance moosehorn
cut speed and slag
- Joe Jones
Re: cut speed and slag
More speed. Lower amperage setting.
Thankyou Joe, I'll give it a try and report the results
don p.s. it amazes me how quick some of you are to help others out,thanks again
I cut 16 ga. at 250 ipm, 45 amps using Hypertherm 45xp or 85 with Duramax torch with FineCut consumables.moosehorn wrote: Fri May 09, 2025 12:06 pm I have been cutting some 16 gauge cold rolled steel with my hypertherm 1000 at 150 inches /min
Thanks David, between you and Joe Jones advice I can't wait to get cutting!
Happy to try to help - as always! Let us know how you make out.moosehorn wrote: Sun May 11, 2025 11:19 am Thanks David, between you and Joe Jones advice I can't wait to get cutting!
Like these guys said, speed it up. I like to test by cutting a straight 24" lines and gradually increasing the speed with each line that I cut. Eventually you will go too fast and it will no longer cut through. This will help to find the optimum cut speed for minimal dross for a given material thickness and amperage combination.
great advice weldguy thank you!
Happy to help
well I am trying a speed of 195 and getting better results than 150 ipm. I have also discovered that when cutting .060 slots I have better quality
by decreasing the path conversion by .001
at least making progress.
- SegoMan DeSigns
No one has mentioned air pressure, I know on the older machines it has to be manually adjusted for each heat range. I would try it on the top setting for the amperage.
