Amazon torch nozzles A120 machine
Hey guys what brand nozzles work best ? Thermal dynamic brand ? Or what are you having best luck with and what brand if ordered off Amazon ?
I seem to go through quite a few nozzles
Basically $3 a piece off Amazon but are these knock offs any good ?
Re: Amazon torch nozzles A120 machine
I have Hypertherm cutters and have great success using the OEM Hypertyerm consumables. I am not familiar with your cutter, but I personally would stay away from the imported knockoffs. Perhaps others have had success with them. I think you can read the Amazon reviews to get some idea of how they are working for others.
- tnbndr
Are you using OEM (Thermal Dynamics) nozzles or aftermarket?
Most manufacturers recommend OEM as they are manufactured to factory specs. Aftermarket could ruin your plasma cutter and if you burn them up frequently, what are you saving.
I had a Hypertherm 45 and always used OEM only and got good use out of them as long as everything was to spec and there was no moisture in the air lines. Moisture will kill consumables faster than anything.
Moisture may be an issue. I have a motorguard filter and an air water seperator. I’ve recently just added a timer automatic drain blowoff as well. I had a ton of water in the tank a few days ago that I drained off when I installed timer, probably 2-3 liters . Water was clean though
I would use the OEM parts and I am with mikeemike73 on the moisture issue. If you see black or grey staines swirling around the shaft of the electrode you need to clean your air up. This is one of the best things you can focus on the improve consumable life in addition to being sure your piercing and cutting at the correct height and speeds.
You most definitely don't want water in your tank. I have a drain valve attached to the bottom of my compressor tank and leave it "cracked" so that it has a continuous small leak that allows any water to escape into a small drain pan. In addition, I use a refrigerated dryer ahead of my plasma cutter. I also use only OEM consumables and have always had great success with my cuts.mikeemike73 wrote: Sun Jan 12, 2025 11:35 am Moisture may be an issue. I have a motorguard filter and an air water seperator. I’ve recently just added a timer automatic drain blowoff as well. I had a ton of water in the tank a few days ago that I drained off when I installed timer, probably 2-3 liters . Water was clean though
where do you purchase oem parts? my local welding supply they are like 3 times the price over online stuffadbuch wrote: Mon Jan 20, 2025 7:33 pmYou most definitely don't want water in your tank. I have a drain valve attached to the bottom of my compressor tank and leave it "cracked" so that it has a continuous small leak that allows any water to escape into a small drain pan. In addition, I use a refrigerated dryer ahead of my plasma cutter. I also use only OEM consumables and have always had great success with my cuts.mikeemike73 wrote: Sun Jan 12, 2025 11:35 am Moisture may be an issue. I have a motorguard filter and an air water seperator. I’ve recently just added a timer automatic drain blowoff as well. I had a ton of water in the tank a few days ago that I drained off when I installed timer, probably 2-3 liters . Water was clean though
also to note i must have water in line . it was spraying out of my air rivet gun and air sander. I have a motorguard filter that i need to replace the internals . im going to invest in a drier . not sure if the plasma unit has a filter in it as well
- Scratch
I have a TD machine for my table and I’ve been using Amazon electrodes and tips for a while now. I haven’t had any problems with them and haven’t noticed a difference in how long they last. I’ll keep buying them.
I just purchased an air dryer
What did you end up buying? A air dryer will make a world of difference. I cannot stress enough how important it is to have the cleanest, driest air possible. Don;t expect miracle results right away after installing the dryer, you will have contamination all through your plasma cutter, 25 foot torch lead, etc. It will get better and better over time as you use it. Let us know what sort of benefits you are seeing as you continue to cut.
Not sure how to post pics
It’s SMC 25cfm unit from KMS tools in Canada
Is this unit? Looks great and would like to hear what you think of it after some time.
Yes that’s the one. It was $1200 CNd . I hope it solves any issue I’m tired of guessingweldguy wrote: Tue Jan 28, 2025 2:13 pm Is this unit? Looks great and would like to hear what you think of it after some time.
Baker's Gasmikeemike73 wrote: Thu Jan 23, 2025 10:36 amwhere do you purchase oem parts? my local welding supply they are like 3 times the price over online stuffadbuch wrote: Mon Jan 20, 2025 7:33 pmYou most definitely don't want water in your tank. I have a drain valve attached to the bottom of my compressor tank and leave it "cracked" so that it has a continuous small leak that allows any water to escape into a small drain pan. In addition, I use a refrigerated dryer ahead of my plasma cutter. I also use only OEM consumables and have always had great success with my cuts.mikeemike73 wrote: Sun Jan 12, 2025 11:35 am Moisture may be an issue. I have a motorguard filter and an air water seperator. I’ve recently just added a timer automatic drain blowoff as well. I had a ton of water in the tank a few days ago that I drained off when I installed timer, probably 2-3 liters . Water was clean though
https://bakersgas.com/
Maybe for TD they work well. Good to know. For Hypertherm, I have always used OEM as I figured it was not worth the risk of damaging one of my cutters.Scratch wrote: Thu Jan 23, 2025 10:57 am I have a TD machine for my table and I’ve been using Amazon electrodes and tips for a while now. I haven’t had any problems with them and haven’t noticed a difference in how long they last. I’ll keep buying them.
That seems like a really decent deal. Be sure to filter your air prior to the new dryer to be sure the air is free of aw water, particulate, and compressor oil. Please post back with your review after you have used it.mikeemike73 wrote: Tue Jan 28, 2025 3:12 pmYes that’s the one. It was $1200 CNd . I hope it solves any issue I’m tired of guessingweldguy wrote: Tue Jan 28, 2025 2:13 pm Is this unit? Looks great and would like to hear what you think of it after some time.
So far this air drier seems to be good. I’ve had no spotty hesitation in starting the torch in am now . Haven’t use it a lot but air most certainly seems dryweldguy wrote: Wed Jan 29, 2025 11:20 amThat seems like a really decent deal. Be sure to filter your air prior to the new dryer to be sure the air is free of aw water, particulate, and compressor oil. Please post back with your review after you have used it.mikeemike73 wrote: Tue Jan 28, 2025 3:12 pmYes that’s the one. It was $1200 CNd . I hope it solves any issue I’m tired of guessingweldguy wrote: Tue Jan 28, 2025 2:13 pm Is this unit? Looks great and would like to hear what you think of it after some time.
That's great, glad it has worked out and your seeing the benefits of clean dry air. It's a big difference no doubt. Thanks for posting back.
