Plasma Table Fluid
All topics related to smoke evacuation, ventilation, and water tables.
Re: Plasma Table Fluid
Creative25 wrote: Sat Jan 18, 2025 10:26 am So I found if I cut regularly I don’t need anything
To stop the water from going bad.
Inuse reverse osmosis water. Which has a low mineral content.
I guess the arc produces enough UV light and ozone to keep the water just enough sanitized to keep the water from starting to smell.
That is good to know! As of late I have only been adding tap water to my water table. It evaporates so fast that I don't need to worry about it going bad. From time to time - I do add some water soluble coolant with the thought that it will help to prevent rust or corrosion to my water tray - which is made from 11ga. steel.
And actually - since I have a combination water tray/draft system - for occasional cutting I will cut with no water and the draft system (exhaust system) is sufficient to remove most of the smoke.
https://photos.app.goo.gl/h8LHufi6frttfGNQA
Return to “Water Tables, Ventilation, Air Handling”
