So I've been reading and reading and then did some more reading and I think I have a good plan. But I'm hoping you guys can steer me in the right direction and help me not do anything dumb
I've decided on a table with a cutting area of 32/48.
Hgr20 for the y axis and sbr16 (not the best I know but 2 rails one on top and one on the side) for the x axis. I'll be running a blowback plasma cutter and I've settled on linuxcnc for control.
Now I might be crazy or this might be weird but It'll be made out of aluminum tubing and won't have legs. It'll sit on my welding table and be stowed away against the wall or a chain hoist to the ceiling when not in use. Don't freak out!
My first step or what I want is to get the gantry and z axis done as this will determine alot of the design afterwards... Wish I could draw pretty pictures in cad for you guys but other than a couple scribbles and measurements most of it is my head haha...
So to my first question:
What is the minimum or good height for my gantry? Of course it's up to me and I've seen pretty much everything but I'm leaning towards 4 or 5 inches to bottom of the gantry with the z axis having the ability to pull the torch 3 or 4 inches above the cutting table.
Thoughts???
Any other criticism? (Please be kind)
Got some parts on the way... Sbr rails for the y axis, 8mm rods, bearings, lead screw nut for the floating torch head z axis and a dial indicator which I've always wanted but never really needed till now
Gosh I'm a blabber sorry haga
