Design Edge - drawing a simple plate example
Fastyankee wrote: Tue Nov 12, 2024 10:48 am I was trying to do this simple plate.
Operations I need to know .
Draw a square with the direct size input
Same with circles
Radius tool or chamfer
Centering The tab to the center of the line edge
Placing tabs perpendicular to each other with spacing
This simple plate covers the basics in drawing a part .
I also can’t seem to get a part to snap to an edge when I place those tabs on the square I just did it by eye so they are not all the same length.
I did it design edge because I love the trim tool but there so much I need to learn.
I was also having issues with adjusting height of part and didn’t realize you just clicked the part, click control height, and then enter the dimension. I was clicking the part clicking control, and then clicking the part again and it would size the whole thing and I was getting frustrated, so things like that if you don’t do them in the right way, they don’t work right and you need to know that I don’t know that stuff.
I saved screenshots of every thing you posted .
I wish I could a class with the guy in OK.
Andrew - I created a set of screen shots showing one method of using Design Edge to create a drawing for a plate similar to the one in your photo. There are many different methods that could be used, this is how I would do it. Let me know if you have any specific questions about my process.
Re: Design Edge - drawing a simple plate example
simple plate to practice drawing.pcm
(17.18 KiB) Downloaded 9 times
Here is the actual pcm file I created when I was making these screen shots. You could open it and try to duplicate what I did at each step.
(1.5 MiB) Not downloaded yet
Don;t have design edge but some of your ideas here will work in my Coerl. Very nice David, thanks for posting.
Fastyankee
Post by Fastyankee »
Thanks Dave I'm finding it way easier to draw parts in Ink Scape because it has such great snapping tool and node editing .
I don't know design edge doesn't have a node editing tool well at least the one they do have is terrible and not a true node editing tool.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Joe Jones
Post by Joe Jones »
Can you make a video showing these Inkscape features that you enjoy? I would like to comare them to DesignEdge myself!
50 Watt GALVO fiber
SwiftShape 3-in-1 machine
CreatBot D600 PRO
Stratasys Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Fastyankee wrote: Tue Nov 19, 2024 6:18 pm Thanks Dave I'm finding it way easier to draw parts in Ink Scape because it has such great snapping tool and node editing .
Andrew - I think that after our phone conversation earlier this evening - you may now have better luck with your snaps, fillets, and such. It just takes a little bit of time to get used to the work flow - it's different than EnRoute, Inkscape, or some of the other cad programs.
Joe Jones
Post by Joe Jones »
It is obvious that Inkscape has a superior note editing capability over design edge. Those are great demonstration videos. I don’t spend a lot of time with Inkscape so I guess it has a lot of features that I am unaware of.
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
