Cutting 2” thickness mild steel
Mayle1994
Post by Mayle1994 »
Im trying to cut 2” thickness mild Steel using 300 amp and 21% speed but the cut comed out this way i show in the attached picture. Any ideas of how i can make the cut better.
Re: Cutting 2” thickness mild steel
Not very familiar with your setup but you say 21% speed. Are you cutting at 21% of the recommended speed?
Mayle1994
Post by Mayle1994 »
No. 21% si the recommended speed
Gotcha, I am used to speed being in inches per minute rather than a percentage.
In the image below showing the cut edge, is the torch cutting from left to right or right to left for this cut?
Mayle1994
Post by Mayle1994 »
Rigth to left
Mayle1994 wrote: Thu Sep 05, 2024 4:21 pm Rigth to left
What kind of plasma cutter are you using?
:Like :Like :Like
Mayle1994
Post by Mayle1994 »
Xpr 300
Deezl Smoke
Post by Deezl Smoke »
What gas are you running and at what ratio?
cutnweld
Post by cutnweld »
i wonder what hypertherm would say, an xpr should be able to make some pretty clean cuts on 2" material. Maybe a bad pierce wrecking the nozzle?
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Durma Brake
Well I am stumped. The bevel indicates possibly a cutting height too low, and the cut edge indicates possibly your traveling a bit fast. As cutnweld mentioned it could be as simple as a damaged nozzle.Worth looking at those possibilities.
PlasmaDon
Post by PlasmaDon »
Or not enough air pressure, or a bunch of things.
Need some more pix, and more information.
Joe Jones
Post by Joe Jones »
I am guessing that the air pressure is too low, and the compressor cannot keep up with the cut.
50 Watt GALVO fiber
SwiftShape 3-in-1 machine
CreatBot D600 PRO
Stratasys Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
PlasmaDon wrote: Mon Oct 28, 2024 8:13 pm Or not enough air pressure, or a bunch of things.
Pictures posted a top of thread.
PlasmaDon
Post by PlasmaDon »
adbuch wrote: Mon Oct 28, 2024 8:39 pm
More pix, like of machine during operation, torch height etc......
