I've been researching how to build a Hypertherm pendant and many of the posts I see (old posts, sadly) are from people who say they have one they've never used.
I am trying to buy one without paying Hypertherm's inflated price. If you have one you'd like to sell please PM me, thaniks.
metalmagpie
WTB Hypertherm pendant
Re: WTB Hypertherm pendant
The price is ridiculous on those. Would be pretty easy to make your own switch box for a few bucks. Does your Hypertherm model has a CPC port on the back of it?
The reason you see them and they are not used is because they are nothing but a way to Manually fire the Machine torch
On the 1000 there are only two signals you can use: Torch Fire and Transfer (Arc OK) there is no divided voltage on MOST of those models. So I am curious....what are you going to do with it>? If its on a manual pantograph table I can see using the torch fire. That is a really simple NO switch between pins 3 and 4 on that CPC connector . Two wires, One switch. 2 wire cable.
- SegoMan DeSigns
Part no's on this thread for components needed:
https://www.plasmaspider.com/viewtopic. ... ns#p214462
I plan to use it on either a track burner or a 'pantograph' mag tracing pattern cutter.tcaudle wrote: ↑Sun Oct 13, 2024 4:09 pm The reason you see them and they are not used is because they are nothing but a way to Manually fire the Machine torch
I think I know how to build a cable. For now, I'm being lazy and trying to find one I can use. A machine interface cable would work for me too, that would get me most of the way to a pendant.
metalmagpie
I got the Hypertherm machine torch connected to my plasma cutter and made an ersatz remote off/on cable and mounted the machine torch on my pantograph-type mag tracing cutter. I test fired it and it worked first time. So I'm not looking for a Hypertherm pendant anymore, thanks.
metalmagpie
metalmagpie
