help scaling DXF files in fusion 360
ArcticMonkey
Post by ArcticMonkey »
Good evening
I recently downloaded a dxf from here and when I put it into canvas in Fusion, I can't figure out how to scale it
Any help would be greatly appreciated
Re: help scaling DXF files in fusion 360
ArcticMonkey wrote: Tue Oct 01, 2024 9:04 pm Good evening
Please show me the Plasmaspider page with the dxf file and I will show you how to scale it using Fusion 360.
Here is an example using a dxf file from Plasmaspider.
I used my example dxf file from this Plasmaspider post.
viewtopic.php?p=240321#p240321
This is the dxf file I used.
Jackolantern(1).dxf
(215.51 KiB) Downloaded 32 times
Jackolantern(1).dxf
ArcticMonkey
DieselFumes
Post by DieselFumes »
Cool Punisher file, thanks for bringing that to my attention!
Davids step by step is perfect and will work all the same on your Punisher design, I just did it myself and worked great scaling it up.
Let us know how you make out with it.
Tracker CNC 4x4
ArcticMonkey
Thanks for all the help
ArcticMonkey
OK so I was able to scale the dxf however unlike last night I can't remember how to attach a sketch to a body. (think that's what I want to do) and use the trin tool to make the two one piece? is that correct and if so, can someone please tell me how to do it
I did take a screen shot but I can't seem to attach it
You can create two separate bodies and then combine into a single body.
Or you can select your imported dxf sketch (with sketch open), select the drawing and then "Ctrl C" to copy. Close the sketch and open the other sketch and then "Ctrl V" to paste. So you have copied the sketch to another sketch which presumably has your other sketched drawing. Then use the move/copy tool to position the pasted sketch to the desired position and use the trim tool to remove the unwanted segments to create a "welded" or "unioned" single sketch. Then extrude the sketch for cutting and/or printing. You can export this finished sketch as dxf.
ArcticMonkey
Good morning and thanks for all the help
I am currently working what feels like 2 jobs and by the time I sit with fusion at night its not till 8pm and by the time 1 am hits it all seems not to make sense
I was able to do this with a the punisher skull the night before but when it cam time to do a buck skull it all seemed like gibberish.
I appreciate both of you helping me!
How do I add screen shots to my post so I can show what I have done and what I am working on?
ArcticMonkey
Well played adbuch with the punisher skull on the body
ArcticMonkey
I am also on a student account with fusion so it seems when you click dropdown menus they seem different than mine
or I may not have the sketch turned on the same way?
I never thought making a sign or fire ring would challenge me so much
ArcticMonkey wrote: Thu Oct 03, 2024 8:10 am
Click on "Attachments" below, then "Add files".
ArcticMonkey wrote: Thu Oct 03, 2024 8:14 am I am also on a student account with fusion so it seems when you click dropdown menus they seem different than mine
The educational account and the hobbyist/personal accounts should have the same drop-down menus. I am using the hobbyist/personal account version.
What is a fire ring?
ArcticMonkey
something like this
but with the punisher logo in it
I am building a slip roller that I designed and cut from fusion
Ill take the flat steel with the punisher dxf on it
fire ring.PNG (176.47 KiB) Viewed 6712 times
design run it though the roller to make a ring
weld the seams
and shazam a fire ring
ArcticMonkey
It will be from one sheet unlike this one
ArcticMonkey
I think what is confusing and giving me the most trouble is if I have a sketch of the fire ring 16 tall 48 long that is a sketch. I draw in my mesh and extrude it and save it as a component
then I extrude the place in the fire ring I want to add the dxf bc I need an opening to put the soon to be extruded part. aka punisher skull
I then import the dxf as a sketch and scale to the opening in the extruded fire ring,
get it to fit and that where the trouble starts.
Unless you are using Fusion 360 to create your cut paths and g-code, you might consider drawing the whole thing with Inkscape. Then save as dxf and import to SheetCam for cut paths and g-code. If you are stuck using Fusion 360 for everything, then draw all or part of it using Inkscape and then import to Fusion 360. Just some ideas.
I drew it up quickly, so the mesh is not uniform. But I think you get the idea. You could do all of this in Fusion 360 as well.
David has a very good point about using Inkscape first if you are familiar with it. If you are not I would stick with fusion.
Here is a quick vid not the best but the rectangle represents your fire ring, the circle represents your punisher skull.
Just follow the moves you see on the screen and you should have no problem but let us know.
FusionJoining.mp4
(18.29 MiB) Downloaded 46 times
FusionJoining.mp4
plasmanewbie wrote: Thu Oct 03, 2024 10:49 am David has a very good point about using Inkscape first if you are familiar with it. If you are not I would stick with fusion.
FusionJoining.mp4
:Like :Like :Like
ArcticMonkey
Thank you both
I apricate the tine it took to send these
I am at work so I will try these when I get home
