StyleCNC drilling attachement, not working.
Daniel DK
Post by Daniel DK »
Hello out there.
I have recently bought a StyleCNC 1325R plasma cutting table with a drilling head attachement.
It cuts great now but, now I am beginning to experiament with the drilling head attachement but, i can not get it working.
I am using the provided software (FastCam, FastNest and FastPlot) for greating some of my files. I layer a squar with on point in the middle that i mark and layer as drilling. I export the file over to the plasmacutter with USB but when i run the file it just uses the plasma torch and blast a small hole in the square, were i originally programmed it to drill...
I am quite at a loss here, hope one of you guys can help....
Best regards
Daniel from Denmark
AREA
Re: StyleCNC drilling attachement, not working.
Post by AREA »
Not at all familiar with your equipment but it sounds like it could be as simple as selecting the wrong tool when doing your post processing. There must be a different tool or process that you select for drilling so it operates the drill and not the plasma.
Daniel DK
Post by Daniel DK »
I just got it working a couple of hours ago, it was a wiring problem within the control unit. But thank you for your answer Area :)
AREA
Post by AREA »
Awesome, glad you got it working. Post some pics of your drilling attachment if you get the chance. Curious what its all about.
