allan from scotland new to plasma cutting
scozy1
Re: allan from scotland new to plasma cutting
Post by scozy1 »
300mm thanks for the help
You appear to have all the settings correct per the Hypertherm cut chart. Even so, it looks like some of your features have incomplete cuts (not cut all the way thru) which would normally make me think that the cut height may be too high. Have you paused your torch while cutting and physically measured your actual cut height?
On some of your cuts, your lead-out is showing as material left on the part. Perhaps get rid of your lead-outs and see what happens.
scozy1
Post by scozy1 »
will check the torch hight today thanks again for the help
scozy1 wrote: Wed Sep 06, 2023 1:13 am will check the torch hight today thanks again for the help
Allan - let us know how you make out with your torch height measurement.
Also, are you cutting hr or cr steel?
