A little help please
Rickzink
Post by Rickzink »
I cannot get the name in the attached to jong the box its in properly. I ahve done this many times now but for some reason I cannot get this one lined out. The spaces between the name int he box should be cut out. How can I get the name and the box to be the same piece?
I hope yall understand my explanation. I am still not familiar with how to easily explain what I need in this world yet.
Gower Hog.svg
(433.29 KiB) Downloaded 103 times
Gower Hog.svg
ROKCRLER
Re: A little help please
Post by ROKCRLER »
Not sure if this is what youre after but...
I separated the groups you had, there were 3 parts
Centered the text with the black frame and unioned
The text box will drop out when cut out of the sign unless you breakup the rectangle in a few spots. I attached a sample.
Gower Hog1.svg
(436.03 KiB) Downloaded 85 times
Gower Hog1.svg
4x8 Dynatorch
PM85
~Mo~
When I open your original file, this is what I see. The rectangular box is only 4 nodes - one at each corner. You need to use the "Stroke to Path" tool on the rectangular box first, then do your Union.
Note: I have switched from Normal view to Outline view to make it easier to see what is really going on here.
As Mo has mentioned, if you are planning to cut this from a single piece the "text in the frame" will fall out when cut. But perhaps you are planning to do a layered piece with the "text in the frame" as the top layer.
ROKCRLER wrote: Tue Aug 15, 2023 6:09 pm Not sure if this is what youre after but...
Mo - did you use the "Stroke to Path" tool on the black frame before you did your Union? When I opened the file, the black frame was only 4 nodes so the Union tool would not work for me until I used the "Stroke to Path" tool first. Maybe you have a different technique that I don't know about.
ROKCRLER
Post by ROKCRLER »
david, yeah i did, forgot to mention it
4x8 Dynatorch
PM85
~Mo~
ROKCRLER wrote: Tue Aug 15, 2023 9:41 pm david, yeah i did, forgot to mention it
Mo - thanks for that! I think that was his main problem - that he forgot to stroke to path before doing his union. I like to work in Outline view for those sorts of things as it makes it easier for me to really see what is going on.
Rickzink
Post by Rickzink »
adbuch wrote: Tue Aug 15, 2023 8:11 pm When I open your original file, this is what I see. The rectangular box is only 4 nodes - one at each corner. You need to use the "Stroke to Path" tool on the rectangular box first, then do your Union.
I am planning to cut this from a single piece. It falling out is the problem I am having with this. I need it to not fall out. Its not a layered piece. I need the cut to stay in it.
ROKCRLER
Post by ROKCRLER »
adbuch wrote: Wed Aug 16, 2023 5:53 am
David, i looked over the file i worked with and i actually differenced the two rectangles to achieve the border... but i do use stroke to path in most cases, on this one i wanted to keep the original sizes Rick was working with.
Rick, is this what youre after?
Gower Hog3.dxf
(612.65 KiB) Downloaded 74 times
Gower Hog3.dxf
4x8 Dynatorch
PM85
~Mo~
I think thats exactly what he is after and it looks great! Nice work guys :Like
Nice work Mo! Here is my take on it. I forgot to stencil the letters.
Gower revised.svg
(61.71 KiB) Downloaded 82 times
Gower revised.svg
Gower revised.dxf
(319.15 KiB) Downloaded 83 times
Gower revised.dxf
after stenciling letters
Rickzink
Post by Rickzink »
Phenomenal work guys!!! Thank you. If you wouldn't mind, can you give me a play by play on what you did? I want to learn from this so I can do it in the future.
ROKCRLER
Post by ROKCRLER »
I'll work on getting screenshots for the method i used in a bit.
4x8 Dynatorch
PM85
~Mo~
Rickzink
Post by Rickzink »
ROKCRLER wrote: Wed Aug 16, 2023 2:33 pm I'll work on getting screenshots for the method i used in a bit.
Awesome!!! Thanks!!!!
ROKCRLER
Post by ROKCRLER »
Let see if this makes sense..
I did not completely finish this one due to all the separate splines and nodes, I can combine them all quicker in QCad than Inkscape, still need to learn that trick..
In QCad, i trimmed the extra lines to make the text and oval like you wanted.
I hope this helps a tad.
4x8 Dynatorch
PM85
~Mo~
ROKCRLER
Post by ROKCRLER »
I redid the file, I went to QCad 100% for this one. The duplicates and disconnected segments were killing me in Inkscape... (i know... DE is one single click...)
Both were checked in Sheetcam, the drawing will need to be scaled up a tad or some small details deleted. This is approx. 27"x17"
Gower Hog_Latest.svg
(263.93 KiB) Downloaded 72 times
Gower Hog_Latest.dxf
(461.14 KiB) Downloaded 78 times
4x8 Dynatorch
PM85
~Mo~
ROKCRLER wrote: Wed Aug 16, 2023 6:00 pm I redid the file, I went to QCad 100% for this one. The duplicates and disconnected segments were killing me in Inkscape... (i know... DE is one single click...)
Mo - I agree - for some of these "store bought" files with all the disconnected path segments - joining/linking with something like Design Edge or CorelDraw will make it much easier to deal with. I suspect the OP does not have access to either of those (or QCad) - so it is what it is. When I import his original file to Design Edge, this is how it looks.
Export from Design Edge and import to Inkscape. Now no "disconnected path segments".
Nice job Mo! I opened your dxf and edited to fix two small open paths and the missing part of one of the chain links. This one should cut very nicely.
Gower Hog_Latest_1.dxf
(199.47 KiB) Downloaded 74 times
ROKCRLER
Post by ROKCRLER »
David I have to agree that the joining feature in DE is pretty sweet, I know we had a similar yet but that easy way in Inkscape, but cannot remember the process.
I'm anxious to see this cut 😁
4x8 Dynatorch
PM85
~Mo~
ROKCRLER wrote: Thu Aug 17, 2023 6:00 am David I have to agree that the joining feature in DE is pretty sweet, I know we had a similar yet but that easy way in Inkscape, but cannot remember the process.
ROKCRLER
Post by ROKCRLER »
That's what I normally do, so it was quicker to bring into QCad.
4x8 Dynatorch
PM85
~Mo~
Rickzink
Post by Rickzink »
Thanks!!! There is a lot of information you provided. I do appreciate it. Is QCad an easier program to use? The reason I am asking is that I am interested in using my table to be able to cut 24 and 26 guage sheet metal for square ductwork. We own a heating and air company and purchased this tbale for that purpose. The learning curve has been larger than I had anticipated but am gaining on it by the day.
At any rate, inkscape seems a little cumbersome, although effective, to use.
ROKCRLER
Post by ROKCRLER »
I cut duct work often, i started drawing them up in QCad but switched to SolidEdge so i can draw in 3D and flatten for cutting.
Inkscape I use only for art stuff, or signs, etc.
QCad is free, but to unlock a few cool needed tools, its only $40 for the license.
4x8 Dynatorch
PM85
~Mo~
Fusion 360 is another good free program for sheet metal work.
Rickzink
Post by Rickzink »
ROKCRLER wrote: Thu Aug 17, 2023 9:09 am I cut duct work often, i started drawing them up in QCad but switched to SolidEdge so i can draw in 3D and flatten for cutting.
Thx!!! How is the learning curve on SolidEdge and what does the cost look like?
Rickzink
Post by Rickzink »
adbuch wrote: Thu Aug 17, 2023 9:13 am Fusion 360 is another good free program for sheet metal work.
Ill look into this one too.
Return to “Inkscape”
