Parts disappear when importing new part???
Tristar500
Post by Tristar500 »
I've got a sheet partially filled and when I attempt to add an additional part one of the existing parts just vanishes.
I can get back to where I started by closing (and not saving) then open the job again.
Tried restarting SheetCam and a reboot of computer.
I'm using the latest version 7.0.21
Notice square part in upper corner is gone when new part is added (new part in lower left corner)
5X7, 6x11 plasma own design
Mach3,4 SheetCam, CorelDRAW 2020 Inkscape .0.92
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
You are only as old as the woman you feel.
Re: Parts disappear when importing new part???
I am fairly sure the red X in the upper left of the screen is an error indicator. That is a older version just loaded today was 7.1.35, if you can hook it to the internet it should update to a newer version which may help.
Tristar500
acourtjester wrote: Wed Jul 26, 2023 4:46 pm I am fairly sure the red X in the upper left of the screen is an error indicator. That is a older version just loaded today was 7.1.35, if you can hook it to the internet it should update to a newer version which may help.
I guess the "check for update" in SheetCam doesn't work as I tried that too. I'll go to the website and d/l as you suggested.
PrimeWeld cut 60
Hypertherm 350
Several mig welders
I am using the full paid version of SheetCam and don't have any problems with the parts disappearing. If you are perhaps using the trial version, maybe that could be causing your problem. As Tom suggested, you may do best to upgrade to the most current version. When I click on the "check for updates" button, it says no updates found - so apparently that button does not work.
Opps!
Post by djreiswig »
Probably not too.smart posting your sheetcam license on a public forum.
djreiswig wrote: Thu Jul 27, 2023 7:03 am Probably not too.smart posting your sheetcam license on a public forum.
:Like :Like :Like
Tristar500
adbuch wrote: Thu Jul 27, 2023 4:24 am I am using the full paid version of SheetCam and don't have any problems with the parts disappearing. If you are perhaps using the trial version, maybe that could be causing your problem. As Tom suggested, you may do best to upgrade to the most current version. When I click on the "check for updates" button, it says no updates found - so apparently that button does not work.
Opps!
I am using the full licensed version.
PrimeWeld cut 60
Hypertherm 350
Several mig welders
The update process is automatic, if the computer is hooked to the internet and you start SheetCam it offers to update at that point, you yes or no then. Like I said yesterday it updated to the new version when I started SheetCam. They are always sending out updates when it is needed. When bugs are found or additions to the service, great company!!
acourtjester wrote: Thu Jul 27, 2023 9:04 am The update process is automatic, if the computer is hooked to the internet and you start SheetCam it offers to update at that point, you yes or no then. Like I said yesterday it updated to the new version when I started SheetCam. They are always sending out updates when it is needed. When bugs are found or additions to the service, great company!!
Tom - mine never asks me if I wish to update. Here is what the opening screen looks like.
Tristar500 wrote: Thu Jul 27, 2023 8:21 am
Perhaps uninstall and reinstall it. Otherwise, reach out to Les Newall at SheetCam for help.
Tristar500
I'm using 7.0.21 which is the current stable version. I wasn't having these issues before. They jus started happening yesterday.
Very frustrating to toss out a half full sheet of material because I can't see the parts in SheetCam.
I need to get a better understanding of "rules" in SheetCam. Is there a good tutorial on this?
Thanks all!
PrimeWeld cut 60
Hypertherm 350
Several mig welders
Here is a tutorial on path rules, but I don't think that is your problem.
Ok one thing is I use SheetCam TNG Development version or SheetCam I canno tell you how many time it has been updated since I stared bock in 2012.
each update only take about minute and restarts SheetCam when it is done.
You can use either version with your license, just download it and install the license. Development does have a few added tools, don't really think that will help with your problem. To do a work around you can cut each part separately to get them done.
sheetcam 2.JPG (55.85 KiB) Viewed 4732 times
Tristar500
I'll give the development version a try.
PrimeWeld cut 60
Hypertherm 350
Several mig welders
I really thin you should go on the SheetCam forum and post you problem there, I have don't that a few times. Les or another member will reply quickly.
It is free just register, but you may need to check back in a day or so to see any replies.
https://forum.sheetcam.com/
Post by djreiswig »
acourtjester wrote: Thu Jul 27, 2023 2:19 pm I really thin you should go on the SheetCam forum and post you problem there, I have don't that a few times. Les or another member will reply quickly.
He already did.
https://forum.sheetcam.com/viewtopic.php?t=9067
And I replied over there, but he's not been back.
Djreiswig - you may be right. Perhaps he mistakenly clicked on "Import drawing" instead of "New part". That will sometimes have the effect of deleting one of the other parts when the new drawing is imported. The fix is to only "Import drawing" once, then use "New part" to add parts to the existing drawing.
I'm not sure why he as the red "X" indicating an error. If he would hover his mouse pointer over the red "X" - the actual error message should be displayed.
Return to “SheetCam”
