SolidWorks dxf problems
HCmillertech wrote: Thu Apr 20, 2023 7:11 pm You seem to be my teacher on here. Thanks you. I have a question for you
> my son is making something and drew it in solidworks and saved it as a dxf.
> when i open it in inkscape it seems to not like it at all. It wont fill
> and really just acts weird.
> Anyway you could tell me how to get the file ready to cut?
> I attached the file
> Thanks!!
Boat Right Side - Copy.DXF
(26.77 KiB) Downloaded 57 times
Hi HC - I have opened your file and this is what I see.
Re: SolidWorks dxf problems
Here is the edited file.
Boat Right Side rev.1.dxf
(1.14 KiB) Downloaded 53 times
PS
I opened your dxf with Inkscape to have a look. Here is what I found. Let me know if you have specific questions about editing your file with Inkscape and I will show you a step-by-step sequence of editing it.
HCmillertech
Post by HCmillertech »
Thank you so much for helping me. He said it was drawn in 3D so maybe this is what happened.
HCmillertech
Ok I wanted to open the fixed file to compare but I am getting this error.
I would like to fix this in inkscape if I can. I ungroup but I am still not able to select the lines to delete them. If you could help me with that process it would be awesome.
Thanks again
HCmillertech wrote: Sun May 14, 2023 9:37 am Ok I wanted to open the fixed file to compare but I am getting this error.
First of all, I am using Inkscape Version 1.2.1
I have my Document Properties set set to inches.
Boat Right Side from Inkscape demo.svg
(2.48 KiB) Downloaded 55 times
Boat Right Side from Inkscape demo.dxf
(4.93 KiB) Downloaded 40 times
TJS
Post by TJS »
adbuch wrote: Mon May 15, 2023 1:41 am SolidWorks dxf 9.jpg
Great info David. In your red text I am trying to see what the node looks like when not joined and when it is joined. What is the difference. It is hard to tell by the screen shot.
T.J.
TJS wrote: Mon May 15, 2023 7:33 am
T.J.
joined nodes.jpg (10.95 KiB) Viewed 1038 times
TJS
Post by TJS »
Thanks again David.
T.J.
Thanks again
PM Sent.
Return to “Inkscape”
