help with broken lines in dxf file
dwmetal
Post by dwmetal »
Hello, i just purchased a file from etsy. I imported it into Corel and i have so many broken lines....so many the file is useless to me. I've messaged the seller...but in the mean time can some one help me fix this?
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
Joe Jones
Re: help with broken lines in dxf file
Post by Joe Jones »
Post the file here, and I will see what it needs.
50 Watt GALVO fiber
SwiftShape 3-in-1 machine
CreatBot D600 PRO
Stratasys Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
dwmetal
Post by dwmetal »
I hope this file uploads. :) Thanks!
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
Joe Jones
Post by Joe Jones »
The file is fine. The paths were just not joined. Here is the corrected file.
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
dwmetal
Post by dwmetal »
Joe, thank you so much! I tried to join them in Corel, but it doesn't work. Do you mind telling me what you did in case i need to do it again in the future?
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
Joe Jones
Post by Joe Jones »
The file was created with several open paths. I simply joined them to make closed paths.
If you have the file, I will delete the uploaded file so the seller can still sell it! You might also delete the file from the post above.
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
dwmetal
Post by dwmetal »
Done, thanks again!
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
dwmetal wrote: Mon Apr 24, 2023 2:32 pm Done, thanks again!
Since you most likely don't have access to Design Edge for your editing, the joining/linking can also be accomplished with several free or very inexpensive programs - namely Inkscape and/or LightBurn. If you would care to send me a PM with your original file, I will show you how to do this.
adunn12
Post by adunn12 »
1: Import into inkscape
2: Immediately SAVE AS
3: choose "save as type:"Desktop Cutting Plotter (autoCAD DXF R12)(*.dxf)
4: import into Torchmate
Done..
Torchmate hates all other versions of DXF other than R12.. Free and fast and easy.
In my personal experience this is inaccurate information. Both versions (dxf R14 and dxf R12) import to TMCad just fine for me.
