Updated the hub Utility firmware from 1.6 to 1.8. Also updated the firmware for DTCH 5. Now the torch will not fire.
Is there more to the process when updating the Hub Utility?
Linux Mini Computer Command CNC 1.2.2
Bladerunner
Bulltear StarLab 5' x 10'
Hypertherm Powermax 85
Updated Hub Utility firmware now torch won't fire
Re: Updated Hub Utility firmware and now the torch will not fire
UPDATE:
Apparently all that was needed is a power down and restart of the hub itself. I unplugged the power supply to the hub for a minute or two and plugged it back in. Seems to be communicating properly now....and the torch fires as it should.
Love those fixes! Thanks for posting back with your solution, may help someone else in the future
