Inkscape: Drawing to Scale
Rickzink
Post by Rickzink »
I have a customer that is requesting I design and cut his address and street. The design doesn’t appear to be overly difficult but the size he is requesting is fairly exact.
I haven’t had occasion to draw something to a tight dimension. How can I do this using Inkscape?
Re: Inkscape: Drawing to Scale
There are locations in the top tool bar for the W and H dimensions. You highlight your item and then change either for the size you want. Select inch or MM for you scale.
inkscape size.JPG (22.12 KiB) Viewed 876 times
As Tom said, just select your drawing and then enter your desired size for width and height in the boxes on the top line. If you wish to keep the aspect ratio the same, then check the box to lock the x and y dimensions together so that they scale in proportion to each other.
heart with hole 1.jpg (60.77 KiB) Viewed 874 times
Rickzink
Post by Rickzink »
Thanks to everyone for their guidance. I wasx thinking it was more complicated than that but your input was spot on exact and the design turned out perfectly sized.
Now I just gotta figure out what is going on with my table. I developed an issue as I was cutting yesterday. Ill post it in the appropriate location.
Thanks again.
Rickzink wrote: Wed Feb 01, 2023 1:33 pm Thanks to everyone for their guidance. I wasx thinking it was more complicated than that but your input was spot on exact and the design turned out perfectly sized.
Thanks again.
We were happy to help. Show us your finished drawing so we can see how you worked it out.
Return to “Inkscape”
