even possible?
Re: even possible?
Pyro1983 wrote: Tue Jan 24, 2023 9:45 pm One last quick question for now...is there a quick , easy way to dimension something in a drawing? For example, on this design, if I make it roughly 5" wide and want to put a 1/4" diameter hole (or whatever size i choose) at the top to hang it, whats the easiest way to make a 1/4" circle or ANY specific sized shape for that matter?
Heart.svg
Pyro1983
Re: even possible?
Post by Pyro1983 »
Thanks for all the info. I messed around, changed it all up after figuring out the process a bit. See any issues with it?
Re: even possible?
I think this one look great. Just one place you might consider editing a bit.
Pyro1983
Re: even possible?
Post by Pyro1983 »
adbuch wrote: Wed Jan 25, 2023 11:51 pm I think this one look great. Just one place you might consider editing a bit.
I'll do that, thanks again
Re: even possible?
Pyro1983 wrote: Thu Jan 26, 2023 8:13 am
Happy to help as always! Let us see your finished heart when cut it.
Pyro1983
Re: even possible?
Post by Pyro1983 »
Here it is without any finish work! It cut well! Cut out of 16 ga
Re: even possible?
That turned out great!! What sort of finish will you use?
Pyro1983
Re: even possible?
Post by Pyro1983 »
adbuch wrote: Sat Jan 28, 2023 7:49 pm That turned out great!! What sort of finish will you use?
Thanks, I'm pretty happy with it. I will probably have it powder coated. I know a guy that does smaller stuff dirt cheap. Not sure what color yet.
Pyro1983
Re: even possible?
Post by Pyro1983 »
Finished product!
ROKCRLER
Re: even possible?
Post by ROKCRLER »
Nicely done!
4x8 Dynatorch
PM85
~Mo~
Re: even possible?
That turned out great! Thanks for sharing your photo. Is that a textured finish?
Pyro1983
Re: even possible?
Post by Pyro1983 »
adbuch wrote: Wed Feb 01, 2023 8:39 pm That turned out great! Thanks for sharing your photo. Is that a textured finish?
Yes, it is wrinkle black powder coat
Re: even possible?
Pyro1983 wrote: Mon Feb 06, 2023 2:18 pm
Thanks! The finish turned out great.
