Little help with Corel Draw DXF
So I have this cut out that I made with Corel draw X5... The problem is when I take it into my Autocad 2004 and try to set it up for layers and what not the program keeps FREEZING...
I have tried the purge command
Polylines
Its in Corel Draw
Polylines
Its in Corel Draw
Re: Little help with Corel Draw DXF
here is the Auto Cad DXF
- Attachments
- 1395dxf.dxf
- (385.25 KiB) Downloaded 106 times
- 1395dxf.dxf
Trying to figure out what step am I missing...
- Chopper John
I can open it with Autocad 2008 and explode it. I did notice you have a lot of duplicate entities....5 to 6 thouasand. Don't know if this helps you as I really don't know much about Corel.
Chopper John
Mad City Cycles, Inc.
How do I delete the duplicates ? Can I do it in Autocad
- greenweanie
if you have the file in jpeg form I can try and trace it and make a cleaner dxf
- greenweanie
there are a couple useful commands in AutoCAD to help clean up files... if you highlight the drawing in a box and in the command line you can type " OVERKILL " . this will will delete alot of duplicate lines.
- greenweanie
oops
- greenweanie
Here is an exploded version..
- Attachments
- 1395 exploded.dxf
- (146.44 KiB) Downloaded 127 times
- 1395 exploded.dxf
overkill not recognized ( I am using 2004)
Hi,
Here is a slightly simplified version with some of the doubles erased. Hope this helps.
Mike
Mike
- Attachments
- 1395dxf.dxf
- Simplified dxf
- (93.95 KiB) Downloaded 111 times
- 1395dxf.dxf
- Simplified dxf
http://www.PenningtonFab.com
Torchmate 3 with Accumove 3
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Lincoln wirematic 250
Eastwood 175 with Spoolgun
Eastwood 135 Mig
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
- greenweanie
I had alot of problems with duplicate lines when i used Corel 3x back in the day, I switched over to Adobe Illustrator, Photoshop, and Vector Magic home version and haven't looked back.
first, for exchanging corel files it is best to use CMX format
importing the first dxf posted, in corel, select all and combine then fill, and it doesn't fill right, the holes are filled, which means the holes must have copies on top of each other
it turned out that everything except the outer oval had 2 copies, so I just deleted one of each hole, then combined all, and it filled correctly, which usually means it's ok,
but actually if you had 3 copies, it might look ok but still not work ok, in which case if you zoom in and look close at the nodes they just don't look normal and there's more than there should be.
it's not a corel issue or error per se, there are many ways to create excess copies like that accidentally
there's no logical reason for autocad to crash on a dxf, can't help you there, except in corel you can choose the dxf output format version, it might be that you are exporting a much later version of dxf, try exporting dxf version 2004 or earlier
- Attachments
- 1395dxf.cmx
- (26.69 KiB) Downloaded 96 times
- 1395dxf.cmx
awesome thanks everybody
