Hello everyone.
I was given a brand new mechanized torch (059477) for free. After doing some research I've read that the 059477 is for the Powermax 45, 65 and 85. Will it work on my 45XP?
Mechanized Torch 059477 Compatible with 45XP?
Re: Mechanized Torch 059477 Compatible with 45XP?
yes it can be used
the touch pinout is on the last few pages of each manual (you will need to look at and follow the schematic, LHS for 45xp, and rhs for 65/85
they are almost the same, there is some slight differences but they should not stop the lead being used. if it doesn't work report back and I'll tell you what to do as the machine may be looking for a torch cable length signal that may or may not be built into the torch connector. you just jumper between two of the pins.
- Francisco
Yes, it is compatible and it´s a far better choice than the flimsy Duramax Lock machine torch meant for the 45XP.
