Hi Josh - Thanks for asking. When you said you are designing in Fusion 360, are you importing dxf or svg files for editing, or is this happening with a file created internally to Fusion 360 with no importing of external files? I am assuming that this is happening to you with imported dxf or svg files.JP1 wrote: ↑ hey man,
you seem to be the man in the know so i have a question maybe you can help me with. when i'm designing in fusion 360 i get some files with way to many node in them for nothing, someone said something about smoothing the file and getting rid of those to be easier to work, is that something i can do on 360? or do i need to use a different software? im not familiar with CAD just beating my way through learning the hard way with vids and advise.
Josh
I am not aware of any smoothing or node reduction tool within Fusion 360. Inkscape does have a Simplify tool which can be useful for elimination overlapping redundant nodes. Files can often be manually edited with Inkscape to reduce nodes while maintaining the overall shape of the drawing paths. LIghtBurn can be used for linking/joining nodes to help eliminate crossovers and unwanted intersections. An unlinked dxf file imported to LightBurn will be automatically linked/joined when the file is exported as dxf. This can often be very useful when preparing vector files for import to SheetCam for creating cut paths.
Perhaps you could share an example file that is giving you problems in Fusion 360, and we can take a look and maybe give you some ideas how to improve your outcome.
