Javelina
ttomlin1
Javelina
Post by ttomlin1 »
Need help converting this image into a dxf file for my machine to cut.
Re: Javelina
What program are you using to try to convert it, and how much progress have you made. You can post screen shots of your work and we will try to help you learn how to do this yourself.
ttomlin1
Re: Javelina
Post by ttomlin1 »
I am using the torchmate cad cam system that was installed on the school computers when we bought the table. The software for some reason does not allow me to just copy the image like it states and I had to try and "trace" this image but it came out terrible
cuttinparts
Re: Javelina
Post by cuttinparts »
I just learned how to use the auto trace feature in Corel Draw and it worked great in this simple design. Hope this helps.
Javs.dxf
Re: Javelina
Here it is with a little bit of editing to remove extraneous nodes and paths.
Javs rev.1.dxf
Javs-rev.1.svg
