Cutting Expanded Metal
Eagle Mtn Metal Works
This is for Jim C at HT or any one that can help me.
I am trying to cut expanded metal and the torch fires when starting and then stops cutting immediately after starting. :?
I have the HT 1250 and it's set on constant cut with the DHC2. Iam using fine cut tips. I have been cutting 16,14ga CR with no problems.
Rod S in AZ
boodog710
Re: Cutting Expanded Metal
Post by boodog710 »
When I cut expanded metal I also turn off the THC.
Thanks' Guys
I do have the rapid restart switched on the torch but I did not turn off the THC I will try that. :lol: This is my first time cutting expanded metal so I guess I learned something new. :lol: Thanks' again
Rod S in AZ
J&S
Post by J&S »
depending on the size of the expanded steel you often have to turn down your cut speed or when the arc starts it will miss a small portion because there is no pierce delay.
FiveORacing
Post by FiveORacing »
Crosscut a piece last week, I turned off the DTHC and lined up a seam so the torch didn't run out of metal.
If I had it do again I would just used a cutoff wheel, I needed to clean up the sharp points anyway. :D
