consumables for ag60 sg55 torch
Information on plasma cutting nozzles, electrodes, and other consumables.
zultek
Post by zultek »
Hello- I have a simadre 60sp that uses a ag60 sg55 torch. I want to find some tips for fine cutting and don't see any options. Please let me know some options, also can I use a different torch style as my torch only has a 2 pin trigger connector a air hose and a red wire for arc voltage. any ideas would be nice
Re: consumables for ag60 sg55 torch
I am not at all familiar with your plasma, you may be best to contact the manufacturer and ask if they offer a tip for fine cutting.
Why are you wanting to replace the torch? Sounds like your torch has all the wires you need.
zultek
Post by zultek »
Hello- was looking for a torch that uses fine cut tips my torch is good but the hole in tip is 0.055 dia. and trying to made a smaller kerf thanks
Greolt
Post by Greolt »
Nozzles can be had in 0.9, 1.0 and 1.2 for that style torch.
I use 0.9 mostly.
zultek
Post by zultek »
Hello- Where do you buy the nozzles
Greolt
Post by Greolt »
zultek
Post by zultek »
Thanks for the info
mechanic416
Post by mechanic416 »
0.9mm/40 amp tips are the smallest you will find for that torch.
Return to “Plasma Consumables”
