setting up a floating head
trucks1948
Post by trucks1948 »
can anyone tell me step by step the correct way to set up my floating head for the z axis.I can't get the actual distances(pierce and cut height) the same as the distances shown in the Mach DRO screen.
Re: setting up a floating head
You need to have a post processor that is setup to add the floating head configuration to the G-code automatically. This post processor is depently on the the electronics you are using and the software. This will add the command G28 for the homing of the Z axis and look at the floating head switch.
If you post the software and the type of interface with the table someone will get back with you to help.
trucks1948
thanks
Return to “SheetCam”
