Fine cut on stainless 1.5mm sheet
Zukzilla
Post by Zukzilla »
Hi guys.
Running a hyperthem 85 with 45 amp fine cut consumables, water table on mach 3 control
Wondering if this is about as good as I'll see from it or if there is a way to dial it in even better.
Thanks for any help.
Re: Fine cut on stainless 1.5mm sheet
Looks pretty good. Are you using lead in's? It looks like it may be piercing on the finished edge but you have little to no dross so it looks good.
Zukzilla
Post by Zukzilla »
2mm arc lead ins very happy with the haz and dross
Looks good. Are you using the Hypertherm recommended settings from the Finecut SS chart?
Zukzilla
Post by Zukzilla »
Sure am David
Zukzilla wrote: Mon Aug 03, 2020 6:46 pm 2mm arc lead ins very happy with the haz and dross
Ya man looks great. I have circled the areas I think you may be able to improve upon with a longer lead in, 2mm is pretty short but ya almost no dross is awesome on stainless. Great work :Like
