Some of you may have seen some projects completed by ourselves or our customers where numerous parallel lines were used to fill in the letters or design being scribed, this creates a unique look that no one would guess you did with a plasma table.
For Inkscape users there is an extension you can add that makes adding these "hatch" lines instant and easy and gives you the ability to adjust the amount of lines, angle of lines, and more and it's called AxiDraw.
You can download AxiDraw from this link https://github.com/evil-mad/axidraw/rel ... aw_256.exe Once downloaded simply run the exe to install the software and the next time you open Inkscape you will see AxiDraw listed in the Extensions drop down menu in Inkscape. Additional information on this extension can be found here https://wiki.evilmadscientist.com/Axidr ... stallation
Below is a video you may find helpful if this is of interest to you and if you use this extension please post pics of what you have made. Have fun!
AxiDraw for Inkscape is awesome for EasyScribe users!
All topics related specifically to the EasyScriber drag style scribe & engraving tool.
1 post
• Page 1 of 1
- EasyScriber
1 post
• Page 1 of 1
Return to “EasyScriber Drag Style Scriber for Hypertherm”
Jump to
- ↳ Introduce Yourself
- ↳ Categorized DXF & SVG Library
- GENERAL FORUMS
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- PLASMA CUTTER FORUMS
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FlashCut CNC Forum
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Star-Lab CNC Forum
- ↳ Tracker CNC Forum
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- METAL FINISHING FORUMS
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
