I’m thinking of purchasing a Tracker CNC 4x4 table which uses their Command and Cut software.
https://www.trackercnc.com/nitro-table
Does Sheetcam have a Command and Cut post processor?
I would like to be able to process everything in Sheetcam and export a file to be used in Command and Cut for the actual cutting as I can't use anything else.
I can’t find any information on the internet regarding this.
Peter
Tracker CNC Sheetcam support
Re: Tracker CNC Sheetcam support
I remember that Sheetcam does have a post for Tracker but it just outputs a .plt or .dxf file. Shouldn't really need a post processor as Trackers software can just open a dxf and cut it no post processor required similar to PlasmaCam.
i have a 4x4 nitro table, and run everything through sheet cam.
it does great for lead in's/outs and offset, also for identifying problems before you cut it.
i do find that it doesn't send all settings to cut and command, you still have to set the speeds, peirce delay, voltage, etc.
i love my tracker table, it's well built, and they are amazing to deal with
